v10 ford vs 8.1 chevy ?
Anyone know the pros and cons [ economy, performance, etc] between the two engines?
There was a tred on this recently. Use the search tab.
here are the con's, once in a great while, somebody buys a V-10 powered truck that isn't up to the high standards that are required to own one. The other con; I'll get back to you after you submit your qualifications to the FTE board members for consideration,,,,,,, }> |
I might add, something i know for sure.At least two of them are not as fast as mine. :-X07
I think what surrounds the engine is more important and only YOU can make that decision on what to drive. :) We can all sit here behind our computer screens in the comfort of our homes or offices and debate HP & Trq ratings, other internet postings on cold knock or spark plug ejections, engine life, or what somebody's brother-in-law's co-worker's sister's husband once heard about when visiting Omaha and talked to a guy at a diner whose cousin knew a guy that ....well...you get the idea... :-X20 Both are good. Drive one of each and see what YOU like. :) As far as engines go, I do not think that you can go wrong with either...depending on its intended mission. |
Originally Posted by Monsta
We can all sit here behind our computer screens in the comfort of our homes or offices and debate HP & Trq ratings, other internet postings on cold knock or spark plug ejections, engine life, or what somebody's brother-in-law's, co-worker's, sister's husband once heard about somewhere when visiting Omaha and talked to a guy at a diner whose cousin knew a guy that ....well...you get the idea... :-X20
I don't think either of the two engines makes or breaks the truck. In other words, I wouldn't buy a Chevy or Ford based on the engine alone.
With Ford you get a Dana front solid axle, manual hubs, high ride height and clearance and for 2005 an available built in break controller. With GM you get IFS, no manual hubs, and a frame clearance that's so low as to nearly render the truck useless for any serious off road work application. Those factors are some of the things I appreciate with the Superduty line. The V10 may not have quite the same low rpm torque as the 8.1L but that's the only advantage the 8.1L has, and it's a very small one. The 6.8L is overall more efficient. It makes more torque/HP per cc, gets better mileage and weighs less. |
Monstas got it right. you'll have to drive each to find out there pros and cons and your own personal prefrence. Its alway nice to have poeple around here with ther head screwed on right so this won't turn this into a big Flaming war, heck my kevlar suit is at the dry cleaners right now so........Anyway my brother in laws sisters husbands dogs best friend had a.... , no my brother inlaw has an 01' 8.1L no complaints other than his fuel mileage says he can't break 11mpg. could have something to do with the way he drives it though, if you know what I mean. I love my V10 and could list everything that is cr%$ on the 8.1 and that is great on the V10 but I won't because you can go to a GM web site and get the opposite response to the same question. It all comes down to YOU, drive what you feel is the better truck and youll be much happier (oh, by the way just to let you in on a little secert, THE FORD IS THE BETTER TRUCK!!! JK) there is a reason we are all at this site and it has to do with what we thought was a supiroir truck so pick what you want.
496'S are some awesome marine engines, not quite sure why Chevy's dominate the marine market,because Ford makes very good marine engines also, but they do.Ford power can make even a V10 a marine engine.Now that would make a good ski-boat powerplant.I have heard that the 8.1's have an oil consumption problem,but since I have never owned one,cant say if that is true or not.I've always believed that the V10 with it's 72 degree firing order compared to a 90 degree firing order, the 6.8 is making power at a faster rate,meaning it has 2 more cyl's firing within the 720 degree cycle than a V8.So it's rate of delivery is better.Just like a 2 cycle makes power twice a fast as a 4 cycle,not saying it makes more power,just at a faster rate.
496's
Actually I own two 496's they sit side by side in my 2004 29 baja outlaw they are an awesome motor. But Iam looking at a V10 in a 2005 F250 to pull that monster. GM for the water FORD for the road.. :-X05
Maybe this is a mistake to bring up, but what is that slapping sound under the hood of the 8.1L?? O yeah- PISTON SLAP!!! http://www.pistonslap.com
i think you may find gm is dumping the engines into mercruisers lap at or near cost, while they have used fords in the past merc. seems to be inlove with gm. take a look at http://www.gm.com/automotive/gmpower...ngines/vortec/, maybe this web site can help out some are made in mexico!
i drove both before ordering my 05 v10, it out pulls the gm 8.1 , sorry i have to agree for now boat chevy, car or truck FORD . allthou how come most of the ski boats made have ford power? for the inboards |
OK, so I've had a few but... The Ford V10 simply kicks a$$..... :-wink If you look at horsepower and TQ per liter that oddball V10 is getting it done. I better stop. :-X22
Hey Ken 04 !! In responce to my thread, what do you mean by " the v10 will do half 0-60 what the 8.1 will do" and " the other con, i'll get back to you after you submit your qualifications to the FTE" ??????????? Did i miss something??
The mags (Pop. Mech, Trucks) have done comparisons in the past, and the bottom line is that for 6.8L vs 8.1L the V10 performs as well or better.
The 3 valve 6.8 should be even better. I'd like to see it included in a current comparison. The GM has the Allison which is a plus. Is the Torqueshift available with the 6.8 this year? |
