Tranny Question...
Did I ask this already????? A couple of years ago I was warming my truck up to come to work. I forgot the choke was on and dropped it into reverse while the motor was revving rather high. A couple of weeks later the tranny started slipping. What did I do to the tranny?
Probably helped the wear along a bit. If that's the only problem it had, you made out OK with that episode.
A few questions come to mind: 1) " a couple years ago"... Is it still slipping? 2) When was the last rebuild, or, band adjustment prior to the, uh, incident? Mike |
I stopped driving it right after that and the shortage of money kept me from working on it, so yes its still slipping.
I dont know. Probably before I bought the truck which was in 97. |
Tranny "slippage" can sometimes be attributed to low fluid level too. Check that out first and then move to the band, you can adjust those also. What tranny is it?
--Mike |
The fluid was full last time I checked it, which is when I drovwe it last. Its the C-6.
