LARGEST TIRES THAT CAN FIT UNDER 2001 FORD RANGER
What are the largest tires that can fit on a 2001 Ford Ranger Edge??? It has 15" rims on it right now...so will 31X10.50's fit???
I have a 2001 15" rims with 31" tires they don't rub at all. DO NOT get Mud Terrain Tires though, they cause horrible road noise and have much worse handling. I have Michellin LTX M/S and love them, if you offroad alot I would get A/Ts such as Goodyear A/Ts. Best of Luck.
I have a weird number on the side of my tires. Can anyone clarify the diameter? It reads "P225 70R15" I know the 15 is the size of the rim and R is radial but what's the 70? My stepdad told me it's centimeters, ah screw it I'll just go measure the tire. So I'll be able to fit 31's under my truck?
[updated:LAST EDITED ON 17-Feb-02 AT 10:24 PM (EST)]I'm not sure if they will fit on XL's I do know 31"s will fit on 2x4 2001 Edges
For This example well say you have 235/75/R15 Standard tire sizing works like this First number is the width of the tire in millimeters (235 mm). Second number is the aspect ratio (its the height of the sidewall) you multiply the second number by the first to get the height of the sidewall so 235mm * 0.75= 176.25mm . r15 is your rim diameter in inches. F So to find your total tire diameter you multipy your sidewall height times two since there's a sidewall on each side of the rim. 176.25mm * 2= 352.5mm Now to convert mm to inches you DIVIDE by 25.4, conversely to convert inches to mm you MULTIPLY by 25.4. So we take the height of both side walls and convert it to inches 352.5mm / 25.4 = 13.88 inches add the height of BOTH sidewalls and the diameter of the rim to obtain the tire diameter 13.88 inches + 15 inches = 29 inches The width of the tire in inches is 235 / 25.4 = 9.25 inches So your tire sixe in inches is 29x9.5 R15 |
I am currently running 265/75/15 tires on my 2000 Ford Ranger and love them! The tire diameter for theses works out to 30.7 inches. This actually did a few things for me. Number one it corrected my speedometer gauge which was previously reading about 5 mph to fast; and Secondly, it lowered my cruising tachometer reading from 2700 rpm at 60 mph to about 2300 rpm at 60! A third benefit of these tires are that they help smooth out the ride. I bought these tires from the local Ford dealership--all terrain tread for street use--BF Goodrich Commando XTs. I have had them on for about a week--no rubbing this far. :)
27.5 inch tire
Originally posted by 2000RangerXL I have a weird number on the side of my tires. Can anyone clarify the diameter? It reads "P225 70R15" I know the 15 is the size of the rim and R is radial but what's the 70? My stepdad told me it's centimeters, ah screw it I'll just go measure the tire. So I'll be able to fit 31's under my truck? |
With some minor rubbing. The Edge sits higher then your truck
I forgot to mention in my post above that I do have the "tow package" installed on my 2000 2X4 Ford Ranger so it does give some extra clearance under the wheel wells. I am running the following tire size: 265/75/15. Still no rubbing so far. :) Also see above message that I posted. The tire diameter measures 30.7 inches.
i have a 2000 ford ranger. ext cab. its 2wd, a v6 3.0 liter. what are the largest possible tires i can fit on without rubbing? i would want a fab tech spindle lift but i'm going to save some money. i would like all terrain tires do any of you know of good tires? i have currently 235 75 R15.
thanks |
2000 ford ranger
thanks |
4x4's and edge models will easily fit a 31/10.50.
I have 32 inch tires on an 04 4x4 with 16 inch wheels. I do not have any rubbing.
so do you think its possible to fit 30S on my 2000 ford ranger
You should fit 30 inch tires with no problem.
