Trying to ID a holley Carb..
I'm having a little trouble with a holley carb... Someone gave me this carb a while ago, they had no idea what it came off of... I don't think it's an o.e. carb for anything because it has a manual choke and 2 fuel feeds.. I posted a bunch of pics in my gallery... Thanks in advance for your help..
https://www.ford-trucks.com/user_gal...?userid=215298 |
Looks like an older double pumper. Check here for your numbers to see if you come up with anything... http://www.mortec.com/carbs.htm
--Mike |
Try this link.
http://www.holley.com/HiOctn/TechSer...Info/4011.html The one shown looks exactly like yours with the exception of the auto choke. |
Great that was exactly what I was looking for :-D , the exploded view looks like a vacuum secondary unit but other than that it's exactly the same... now I just need to find an adapter to put it on a spreadbore intake... Thanks again for the help:-X25
It looks like it might be a 4010 750 cfm
well, it's actually a 4013 but it's the same as the 4010 and the 4011 for the rebuild kit at least.... I noticed the picture of the 4010 shows the vacuum secondaries even though the part number that holley shows is for a mechanical... from what I found on holley's website it's a universal 750 cfm double pumper with a standard square bore mount.. no info as to how old it could be... I don't think it's too old because it uses torx screws to hold everything together versus regular slotted screws like the real old ones.... I think I'm going to bolt it on and see how well it works (IF it works) before I go get a rebuild kit or anything...
