U dont need a egt on a non turbo because the turbo is wat rises the temp. All the extra fuel not burnt will go out the exhaust. The most propane will incress ur egt's is like 100-200 degrees no matter how much fuel is dumped in there
Originally Posted by 93idi7.3
(Post 10122714)
Hehehe that truck died years ago! I got a 97 powerstroke now! I finally figured out LEAVE IT ALONE IT WILL LAST LONGER!
more fuel for a over fueled engine???
forget the propane or turning up the pump until you can get rid of the black smoke under load. ie: you need more air...... once you install a pyro meter. to get your base line. install a stock sized turbo. if your engine never came with one, size it appropriatly. review your new pyro temps. then start adding more fuel, injection timing, propane, new cam(s), change compression, ect. remember the propane is to help burn the fuel that doesn't atomize properly. any black smoke you see is just wasted fuel. cc |
i dont know what you would use to turn the solinoid on and off besides a switch on the pedal, i just got my propane kit built and put on my truck tonight have not got a chance to go and drive it yet had a few to many, but i used an adjustable pressure switch to control my solinoid, mine is in line to my map sensor and i used a 12/24v air solinoid to turn the flow on and off, i used a adjustable pressure/flow regulator from tejassmokers.com, got mine set at 10psi right now but i have a powerstroke and get up to 23psi of boost under heavy load and 3800rpm. my brothers friend is running the same set up on his sd as i just built and his works great he has about a 50hp increase with his set at 12psi. you can get the air soliniods from a place that supplies air horns for vehicles they would know exactly what you need. i would really like to know what kind of increase you get when you get it figured out cause i am looking for some more poewer for my 87 ford ranger and i have a 7.3l idi in it and there is not room with how i have it in to fit a turbo so any extra power the better
Originally Posted by 89ford73
(Post 2096731)
my granda gives me free diesel., its red
just get a hobbes switch, they come in two forms of pressure sensing.
low pressure/vacuum. or high pressure/boost. they are available at most parts stores. (they are like a low oil pressure switch). i used one with a water injection system on a high compression gas engine.. |
(Post 10122714)
