License Plate
I saw today in Little Rock Ar a newer F150 today with Indiana plates and at the bottom of the plate it said "Truck 7,000" Whats that all about?
That sounds like a weight registration... F150 7,000 gross, F250 9,000 gross, F350 11,000 gross, etc...
Yes, but you can also get 9000# plates for a f-150 but it costs more.
Thanks, when I saw the plate I figured that was a weight classification. Just wanted to be sure.
Theo's got it right. The only problem is that you can just about put any plate on any vehicle regardless of its actual GVWR. I've seen 7k plates on Eagle Summit Wagons (yeah, riiiiiiiight, that'll move 7k), and I've seen passenger car plates on 1-ton vehicles. The BMV doesn't MAKE you plate properly. The only trouble is that when you get in an accident, an alert cop could give you some trouble if you don't have the proper plate for the weight you actually were at the time of the accident. And, yes, you can put a heavier plate on, but the heavier the plate rating, the more you pay.
Jason |
you can over come some of the bumper laws nad lane widths with 16000 lbs tags
