P0358 Ignition Coil H Primary/sec Circuit Error
Ok, just changed the plugs in my 99 F150 w/ the 5.4 engine. I followed the directions to the letter that I was given from this site. Now I'm getting that code and a rough idle. How do I know which coil is labeled "H"? I need to fix this tonight. Have to go to work tomorrow in it. HELP, HELP, HELP!!!!!! :'(
Identifying coil locations
Never mind everyone. The coil wire to the #8 cylinder was not plugged in all the way.
Anyway, I figured this out. right bank, front to rear #1 cyl, coil A #2 cyl, coil B #3 cyl, coil C #4 cyl, coil D left bank, front to rear #5 cyl, coil E #6 cyl, coil F #7 cyl, coil G #8 cyl, coil H May not be news to some, but I couldn't find the i.d. anywhere on this site. If it's there, I couldn't find it. If it's not, now it is. I hope it helps someone!!! |
Thanks for the info, I'm sure somebody will be needing it :)
As many times as I have been helped here, I'm glad to be able to give some back!!
By the way, I love your avitar, I am a big #6 fan myself :)
