Fuse panel diagram?
Anybody have a fuse panel diagram for a 2000 F-250 with the PSD? Mine came with no manual, and the Haynes I just picked up doesn't have it either...
Interior Fuse Panel
http://www.clubfte.com/users/homerwi...000SDfuse1.jpg Fuse/Relay Location Fuse Amp Rating Passenger Compartment Fuse Panel Description 1 20A Turn/Hazard Lamps 2 10A Airbag Module 3 20A Cigar Lighter, Data Link Connector 4 10A Glove Box Lamp, Map Lamps, Power Mirrors, Underhood Lamp 5 — Not Used 6 — Not Used 7 5A Power Window/Lock Switch Illumination 8 5A Radio, Headlamp Switch Illumination 9 — Not Used 10 15A Dual Fuel Tanks 11 30A Wiper Motor, Wiper Run/Park Relay Coil, Wiper Hi/LO Relay Coil, Washer Pump Relay Coil 12 15A Horn 13 20A Stop Lamps, Center High-mount Stop Lamp, Trailer Tow Stop Lamp, Speed Control 14 10A Dome Lamp, Cargo Lamp, Courtesy Lamps, Running Board Lamps 15 5A Stop Lamp Switch (Logic): Generic Electronic Module (GEM), Powertrain Control Module (PCM), Four Wheel Anti-lock Brake System (4WABS) Module, Brake Shift Interlock, Cluster and PCM Keep Alive Memory 16 15A Instrument Cluster, Hi-beam Headlamps 17 — Not Used 18 — Not Used 150 Fuse/Relay Location Fuse Amp Rating Passenger Compartment Fuse Panel Description 19 10A Auxiliary Powertrain Control Module (APCM) (Diesel only), Instrument Cluster, GEM Module, Overdrive Cancel Switch, Idle Validation Switch (Diesel only), Overhead Console, Diesel PCM via Clutch 20 15A Starter Motor Relay Coil, Clutch Switch 21 — Not Used 22 10A Air Bag Module, Passenger Air Bag Activation/Deactivation Switch, Blower Motor Relay Coil 23 — Not Used 24 10A A/C Clutch, Blend Door Actuator, Trailer Tow Battery Charge Relay Coil, Four Wheel Anti-Lock Brake System (4WABS), Turn Signal 25 — Not Used 26 — Not Used 27 10A Ignition Run Power Feed (Customer Access) 28 10A Brake Shift Interlock, DRL Relay Coil, Speed Control Module, Backup Lamps, Trailer Tow Backup Lamp Relay Coil, Electronic Shift On The Fly Hub Lock Solenoid, Vacuum Pump Motor 29 5A Instrument Cluster (Charge and Airbag Warning Lamps) 30 30A PCM Relay Coil, Ignition Coil (Gasoline only), Fuel Heater (Diesel only), Wastegate Solenoid (Diesel only), Injector Driver Module Relay Coil (Diesel only) 31 — Not Used Relay 1 — Interior Lamp Relay Relay 2 — Not Used Relay 3 — Horn Relay 4 — Power Window One Touch Down Relay Relay 5 — Accessory Delay Relay Under hood power distribution box http://www.clubfte.com/users/homerwi...000SDfuse2.jpg Fuse/Relay Location Fuse Amp Rating Power Distribution Box Description 1 7.5A * Trailer Tow Left Stop/Turn Lamp 2 10A* Washer Pump 3 7.5A* Trailer Tow Right Stop/Turn Lamp 4 20A* Trailer Tow Backup Lamps, Trailer Tow Park Lamps 5 20A* (Gasoline only) 5A* (Diesel only) Gasoline only-PCM, Fuel Pump Relay Coil, Mass Air Flow Sensor, Fuel Injectors Diesel only-Dual Alternator A Field 6 10A* Gasoline only-A/C (CASS) Diesel only-Single or Dual Alternator A Field, Regulator 7 20A* (Gasoline only) 5A* (Diesel only) Gasoline only-Vapor Management Valve, HEGO Sensors, Intake Manifold Communication Control, EVR Solenoid, PCM, Canister Vent Solenoid Diesel only-Dual Alternator A Field 8 15A* Trailer Tow Electronic Brake Illumination, Park Lamps, Trailer Tow Park Lamp Relay Coil 9 10A* Left Headlamp (Low Beam) 10 20A* Power Point 11 10A* Right Headlamp (Low Beam) 12 15A* Daytime Running Lamps (DRL) Resistor 13 30A** Multi-function Switch, Headlamps 14 60A** Anti-Lock Brake System 15 — Not Used 16 30A** Trailer Tow Battery Charge 17 30A** Electronic Shift On The Fly Relay, Transfer Case Shift Motor 18 30A** Power Seat 19 20A** Fuel Pump Motor, PCM 20 50A** Ignition Switch (B4 & B5) 153 Fuse/Relay Location Fuse Amp Rating Power Distribution Box Description 21 50A** Ignition Switch (B1 & B3) 22 50A** Junction Box Battery Feed 23 40A** Blower Motor 24 30A** (Gasoline only) 20A** (Diesel only) PCM Power 25 30A*** Power Windows 26 20A** If equipped with Remote Keyless Entry-Driver Door Unlock Relay Coil, All Door Unlock Relay Coil, All Door Lock Relay Coil, Park Lamp Flash Relay, If not equipped with Remote Keyless Entry-Power Door Lock Motors 27 - (Gasoline only) 30A** (Diesel only) Gasoline only-Not Used Diesel only-Injector Driver Module 28 30A** Trailer Tow Electronic Brake Controller 29 20A** Radio 30 -- PCM Power Relay 31 -- Blower Motor Relay 32 -- A/C CASS (Gasoline only), Injector Driver Module Power Relay (Diesel only) 33 -- Washer Pump Relay 34 -- Windshield Wiper Park/Run Relay 35 -- Windshield Wiper HI/LO Relay 36 -- A/C Clutch Diode 37 -- PCM Diode 38 -- Trailer Tow Backup Lamp Relay 39 -- Trailer Tow Battery Charge Relay 40 -- Electronic Shift On The Fly Relay #1 41 — Electronic Shift On The Fly Relay #2 |
I don't need a diagram, I don't even have a PS but I continue to be impressed by what people here on FTE will do to help others out. Great job HomerWinzlow. Thanks for taking the time to do this.
You are awesome, Homer... Thanks a million!
Glad to help when I can.. :)
can anyone tell me where:
38 -- Trailer Tow Backup Lamp Relay 39 -- Trailer Tow Battery Charge Relay are located on a 2001 F250 superduty? The above diagram is the only one i can find but it excludes those two... |
38 -- Trailer Tow Backup Lamp Relay 39 -- Trailer Tow Battery Charge Relay are located on a 2001 F250 superduty? The above diagram is the only one i can find but it excludes those two... If you just need to know the fuse numbers for 2001, it is maxi fuses 16 and 17 in the power distribution box. |
you can download your owners manual here https://www.fleet.ford.com/maintenan...ls/default.asp
but take out the s
Thank you thank you
You can also download them for free at www.motorcraftservice.com
Click on Owner's Guides on the left and then enter your vehicle info. |
Thanks for the diagram Homer. A good post long after it was written.:-X0A6
Originally Posted by rbaker6336
(Post 5722358)
Sorry guys need to reopen
Hey guys, sorry to reopen an old thread, however I have wired in my plow controller to the pink and blue wire under the dash that runs along with the customer access wires, this fuse is supposed to be fused hot with key from the under dash fuse panel, my million dollar question, does the relay that is located in relay slot 5 have anything to do with power to this wire? Or any other relays or fuses? My plow wiring works perfect, however my controller does not turn on. I know the controller is perfect because I placed the plow in my driveway 10 mins before attempting to power it with other truck
(Post 5722358)
https://www.fleet.ford.com/partsands...owner-manuals/ |
