Head Torque for 4.2
I am looking for the proper torque for the heads on 4.2 V-6's, a friend of mine has had one rebuilt, and doesnt know the torque specs.... found the specs but the book I found listed the head bolt torque at 36 ft-lbs... that seems awful light. What do you guys think?
Thanks for any help. Tim |
Sorry. i hate to leave you hanging with no replies...but I really have no idea. I would suggest going to your local library and checking out a Chilton or Hayes if they have one. Most do. Sorry I am not much help...
torque specs: FT-lbs unless otherwise indicated
cylinder head bolts (oiled) step 1...............................168 in-lbs step 2...............................29 step 3...............................36 caution: when following the torque sequence for the V-6 engine, at step 4 do not loosen all the bolts at the same time or the gasket will not seal properly. loosen the first bolt in the sequence, tighten it to final torque (steps 5 and 6) then go to the next bolt in the sequence, loosening and tightening the bolts untill the sequence is completed. step 4..............................loosen 3 turns ( do not loosen all bolts here. follow caution) step 5 long bolts..................30 to 36 short bolts.................15 to 22 step 6(all bolts).................tighten an additional 175 to 185 degrees get yourself a haynes manual! as i was told to do recently.....they are invaluable, and interesting |
Thanks Guys
I will forward this to my friend, and see if he has come up with some specs as well.
Thanks Tim |
Go to Google and ask about expc 4.2 torque and they will tel you all the expc For your engine
Originally Posted by Binder Guy
(Post 1577876)
