1990 2.9 ford ranger firing order?
Can someone tell me the firing order? :-huh
I changed the cap and rotor and mixed up the order. :( Thanks Oliver |
142536. The distributor turns clockwise looking from the top. The passenger side starting from the front cylinder is 123, and the drivers side starting from the front is 456. The cap should show you which one is #1. It should be located to the rear left (looking from the front of the engine.) Hope that helps.
