good place to post 7.3L diesel parts for sale in BC?
A handicapped friend of mine in Chilliwack has a parts '91 7.3L (broke a rod in half and did a little damage to the bottom of the block and oil pan) and an '89 E350 van for parts (near new E4OD trans)
He needs to get the injector pump in his '91 E350 adjusted (somehow it lost a notch when I pulled the motor to swap because I had to pull the injector pump to remove it) I put an '89 motor in, which was running excellent before I swapped. His income is extremely low, so he is stuck unless I can figure this out. |
