Ford Truck Enthusiasts Forums
-   Bio-diesel, Propane & Alternative Diesel Engine Fuels (https://www.ford-trucks.com/forums/forum168/)
-   -   Propane injection ??? (https://www.ford-trucks.com/forums/175171-propane-injection.html)
CHACH 11-25-2003 06:13 PM
Has anyone installed one of these in our kind of motor ?? Can it be done and what sort of results would normally be expected ???
Chach:-X02
Greentree 11-26-2003 02:54 PM
Converting a diesel engine to burn propane really doesn't make any sense. But just for argument's sake, let's see what would be involved.
In any internal combustion engine the fuel must start to burn in the cylinder at precisely the right moment. Because of compression ignition, this eliminates introducing gaseous propane into the intake manifold like they do with spark ignition motors. As the piston began to rise, the heat of compression would immediately cause the charge to detonate. There's no way to control when the burn begins.
This implies mechanically injecting liquid propane into the cylinder in the same manner as diesel fuel. Hmm, injecting liquid propane at high pressure: I wonder what kind of pump could do that, especially since the lubricating properties of liquid propane are probably zilch. Once the liquid propane is in the cylinder, it must vaporize. The evaporting propane would absorb a considerable amount of heat and ...
Do you see there's no overriding advantage to such a setup? We spend extra money on diesel engines because it burns a fuel that has a higher heat content per cc, is easier to refine, and costs less (at least it's supposed to!). That translates to savings. Figuring out how to do it with propane as a fuel is a lot of pain for no gain compared to a spark ignition motor.
Greentree 11-26-2003 03:20 PM
Well heck. I guess you're referring to a propane boost system such as that at http://www.dieselperformanceproducts.com/home.html.
My misunderstanding. :-X03
beretzs 11-26-2003 05:36 PM
I was trackin with you CHACH. I think alot of fellers do it. Try it, I need someone to be a guinea pig for it. Alot of guys claim it is the way to go, even when combined with a turbo. Scotty
CHACH 11-26-2003 06:35 PM
I stopped into my local (no)discount performance shop amd they showed me a bully-dog setup that they wanted like $600 and thats w/o a tank. You have to build/buy your on tank. And they said it gave 80 hp ... If I could find it cheaper,maybe direct, is 80 hp worth it ???
Chach
Spectramac 11-26-2003 09:57 PM
I've heard the only prerequisit is a turbo charged diesel. I'd like to try it someday.
