correct spark plug gap for a 93 f150 5.0
would any one happend to no the the correct gap for the motorcraft plugs for a 93f150 5.0 i was told 0.54 by the auto part store is this correct. thanks
Dee, There is a sticker under the hood that should tell you the correct spark plug gap , I beleive for your engine it is .044 to .046 . 054 sounds like a little too much , the info on the sticker will be correct .
Chiltons lists .044 as the gap for the 93 5.0.
thanks for the info, i no .054 sound like to much
[font size="1" color="#FF0000"]LAST EDITED ON 18-May-01 AT 05:33 PM (EST)[/font][p]I have a 92 F150 with a 302 and a 92 Grand Marquis with a 4.6 and both are gapped at .054. What does the sticker under your hood say it should be?
My 93 302 says .052-.056 on the underhood sticker. I think when I was still using the factory ignition setup, I set it at .054 to be safe.
Just bought a set of NGK plugs at the auto store. They are pre-gapped at .054. The AUTOLITE plugs (FORD) are also pre-gapped at .054. The underhood sticker says .054-.056. The Haynes manual says, however to use .044??!! Stick with the underhood specs and the pre-gapped settings. If u are using a high energy ignition and wire set then I would gap them a bit wider as well.
what is the correct timing for a 90 f150 4wd 5.0 engine and where exactly is the marks I found a large on one but no little ones so is the large one right. i had to pull the dist out to change the module and forgot to mark the dist.
10 degrees BTDC, the scale is on the passenger side of the block.
How did you find this thread from almost 8 years ago :eek: ?
