Originally Posted by BowlerGT
Guess I should of specified we plan on taking the camper out every weekend or so throughout the spring-fall. We live in Ohio and plan on driving up to 3-4 hours away which means driving through the mountains in SE ohio into west virginia and sometimes down to Tennessee. Would a gas engine still work with where Id be towing or will the extra torque of the diesel help? How do you guys do with the open diffs in these trucks since they only have the electronic locking diff in 4x4?
I used to have a 2011 F150 with the electronic locker and Id much rather have a regular limited slip. Are the superdutys the same meaning you can only lock it in 4x4?
(Post 16518320)
No, you can lock in the rear locker in just 2wd. With the traction control, the brakes are applied to the tires that starts to slip, engaging the other tire turning the open rear end into a semi sorta limited slip rear end. It's not as seamless as limited slip, but does work and will keep you pointed straight. If you put it in 4wd, you will never need the rear locker on the road. It's nice when you have some really soupy mud.
Yeah, the locker can be engaged or not as desired, 2WD, 4HI, 4LO, whatever. And it is NOT mutually exclusive with LSD. It's also an LSD. No reason not to get it. Please get it.
No reason not to get it in a new truck, I wouldn't pass on a used truck that I liked just because it didn't have it.
Someone please correct me if I'm wrong...The electronic locker will disengage once you hit 15-20 mph? Also, the electronic locker is a more rigid lock up than the LSD?
Correct, much more rigid. It is a true locker.
Originally Posted by Ron94150
(Post 16518487)
Makes sense...especially in a worst case scenario...one tire on ice and one tire on dry pavement. And the safety override at speed would help keep people from wrecking their driveline if they forgot to unlock it. Thanks Ron94150. |
It's pretty slick feature to have, I was surprised how quickly too it locks up the diff.
Originally Posted by '65Ford
(Post 16518481)
And it is NOT mutually exclusive with LSD. It's also an LSD. |
1 Attachment(s)
Attachment 156913
It's not possible to get a limited slip and e-locker. I don't know how you would be able to build one, the locker and the limited slip/open carriers go in the same place. |
I kept my 2009 Taco that could not tow the 7000# and bought a decent 95 F350 Diesel to tow my 5th with.
Subscribed as I am in the same boat...
