Try a fuel pressure regulator, from the symptoms you mentioned, its fairly cheap and easy to do!
Originally Posted by couleeman
It has seemed to do the trick (fuel pressure regulator). I just don't want to post to soon and then have the problem arise again because I didn't get to drive it enough and test it out. I will post by the end of the week to confirm it solved the problem. The old fuel pressure regulator was bad though.
