2000 F350 Dash Removal
How do I remove the dash panel of our 2000 F350? The climate control cluster needs to be replaced after 270,000 miles.....:-D
I'm not sure but I think it is just cliped and should pop out. That is what I found on My 99 when I was checking the lights.
WOW 270,000 thats great. Have you had to do anything to it other than change oil and put fuel in it? |
1. remove radio
2. loosen (2) 9/32 screws underneath the top part of the dash where the radio was. 3. pull firmly on dash panel to remove. 4. remove ESOF/power point and any other electrical plugs from dash panel. you should have access to a/c panel fairly easy now. |
