leveling 1970 f250 CS
Has anyone found any type of bolt on kit to raise the front of these trucks. It doesn't need to be level but 2 inches would be nice. Ive found coil spring spacers for about any truck besides these. This is not any top priority, its just on the wish list.
It's more simple, in principle, to lower the rear than raise the front due to the induced camber change.
You really need to sit down and look at the front suspension and see what would happen. |
I just got done looking at the front suspension. I see how even 2 inches would change the angle that the wheels hit the ground. I guess i was hoping it could be as easy as some of the little spacer kits that you see available for almost everything else. I don't think I want to lower the back. I think i like the high ass end better than bringing it down.
Buy new front springs, the ones on are probably sacked and remove the rear leaves the po added for the camper.
