My speedometer is not working on 2005 excursion,Engine light on, abs light on and overdrive blinking
Hi
I have 2005 ford excursion with 24300 miles. My speedometer is not working, engine light on , abs light one, overdrive flashing. I just changed speed sensor on rearend, but my speedometer still not working. Need to know how to fix. Thanks |
Take a look at:
https://www.ford-trucks.com/forums/1...inking-od.html or https://www.ford-trucks.com/forums/9...esnt-work.html or https://www.ford-trucks.com/forums/7...goes-nuts.html See if any of the above is helpful. |
Did everything but the speedometer get fixed with the new VSS?
When mine had the same symptoms it ended up being the ABS module computer. |
I have changed vss , but not working.
What codes are you getting from the CEL?
