1998 F-150 Fuse Info!
I have an 1998 F-150, 4.6L 5 spd, a/c, Power windows-Doors, and cd-fm-cassette. The first problem is that the check engine light stays on. I had it checked and the EGR valve was the supposed culprit.! I got a new one and the light still is lit up! After about a 1000 miles I pulled the Battery Cables to reset the computer. After about 20 miles It lit back up and the diagnoses was the same! Any suggestions?
The pther problem is that My dash lights went out which caused the tail lights to go out as well. After sometime because of the many fuses, I found the bad fuse and replaced it. During that time, I found 2 other blown fuses and I replaced them as well. But I have no idea what the fuses controled. There was no change in anything. I have looked all over hell and Half of Montana trying to find some kind of fuse guide to tell me what circuits the fuses control. There is no info in the truck. Can you tell me where I can get a reference to all of the fuses? Thanx! Paul |
These are for 97 but should be the same.
Position Amps Description 1 15 Stop/turn lamps and turn indicators 2 5 Instrument cluster 3 25 Cigarette lighter 4 5 Power mirrors, autolamp, remote anti-theft/keyless entry, headlamp relay and parking lamp relay 5 15 Speed control, daytime running lamps, climate control blend door, backup lamps, A/C clutch coil 6 5 Brake-shift interlock, generic electronic module (GEM)/central timer module (CTM) and air suspension module 7 - Not used 8 5 Radio, remote anti-theft/keyless entry, GEM module/CTM module Position Amps Description 9 - Not used 10 - Not used 11 30 Wiper system 12 5 On-board diagnostic (OBD II) data link connector 13 15 Brake ON/OFF switch, rear anti-lock brake module and brake pressure switch 14 15 Interior lamps and accessory delay relay 15 5 GEM module/CTM module 16 20 High beam headlamps 17 - Not used 18 5 Instrument illumination 19 10 Air bag diagnostic monitor, instrument cluster 20 5 GEM module/CTM module and powertrain control module (PCM) 21 15 Starter relay 22 10 Air bag diagnostic monitor and passenger air bag deactivate switch 23 10 4WD clutch relay, electronic flasher, 4WD/2WD vacuum solenoids and trailer tow battery charge relay 24 10 I/P blower relay 25 5 4WABS module and relay 26 10 Right low beam headlamp and DRL module 27 5 Foglamp relay 28 10 Left low beam headlamp 29 5 Autolamp, instrument cluster, transmission control indicator lamp and switch 30 30 Ignition coils and PCM relay 31 - Not used THis is the interior fuse panel |
Fuses
Position Amps Description 1 20 Trailer tow back-up and tail lamps 2 10 Air bag diagnostic monitor 3 15 Power locks 4 15 Air suspension 5 20 Horn 6 15 Audio system 7 15 Parking and tail lamps 8 30 Headlamps 9 15 Daytime running lamps and fog lamps 10 25 Auxiliary power point 11 - Not used 12 - Not used 13 - Not used 14 60/20 4WABS/rear anti-lock brake 15 50 Air suspension compressor 16 40 Trailer tow battery charge and stop/turn lamps 17 30 4WD transfer case shift motor and clutch 18 30 Driver power seat 19 20 Fuel pump 20 50 Instrument panel fuse panel ignition switch feed 21 50 Instrument panel fuse panel ignition switch feed 22 50 I/P fuse panel battery feed 23 40 I/P blower 24 30 PCM power 25 30 Power windows 26 - Not used 27 - Not used 28 30 Trailer tow electronic brake 29 - Not used This is the power distribution box |
I don't get to this Computer much. So I haven't forgot you. So once again Thanx!
