Brake problem
I have a 1987 ford f700 having trouble with
The parking brake it has the hydro boost Brake system when I press in the parking Brake the brake pedal get hard and in possible To press Any thought ?? |
Your parking brake, is it a yellow "pull for brake/push to release" knob on the dash?
Yes that's right and it has two lock down chambers on the rear breaks
Can you see the words "Lucas Girling" anywhere on any parts?
Yes that's what it is foreshore
OK to get you going read this thread on the subject. Note there is a link to tools in post 3:
https://www.ford-trucks.com/forums/9...ke-system.html More detail and links: https://www.ford-trucks.com/forums/1...1995-f700.html OK I gotta stop here: Are you a good wrench man with brake experience? In my opinion, a medium truck with this kind of braking system is not something to tinker with and try to learn in the field. If you are not comfortable with this, find a shop, or at least run down a factory manual to consult while working on it. Downloads here, google will be your friend: Ford F600 Lucas Girling Brake System > Priority Documents |
