Aftermarket Brake Booster
So my '54 F250 came with an aftermarket brake booster mounted under the floor on the drivers side frame rail.
To get the reservoir cap,you have go to underneath the truck to get to it.There might be 2 inches of clearance. Anyone with this set up? Did you cut a hole in the floor for access? |
There is a remote filler cap available from wildwood I belive. You attach that the the reservoir and place the remote filler easily accessible.....
I bought one from Summit I believe. 89.00 plus shipping.Ran the dual lines thru the floor where the gas tank was in my 56. Used a grommet and built a mount.
Just filled and bled the brakes on a new system last Sat. without any problems. Summit has free shipping to. |
Thanks for the info.
