Re-Programming the Remote Keyless Entry
I have the procedure to re-program (add a new remote to) the remote keyless entry on 1994 (and similar) F-Series. The procedure first involves jumping some pins at the "programming connector" so said to be located at the base of the steering column.
Does anyone know which (of the many) connectors this refers to? |
O.K. It is a gray two wire connector. There is nothing plugged in to it. It is located right behind the little cubby hole thingy to the right lower area of the column. When you jump it the locks should cycle. This confirms that you are in program mode. Then you need all remotes you will be using with this truck. One at a time lock or unlock the doors. Make sure you program all remotes at the same time, I blieve the system is set up for up to 4 remotes.
got it working, thanks!
I can't see any connector behind the little cubby hole thingy on my 94 F150. It also has the factory alarm --- does that make a difference?
Jim |
1994 F-150 XLT reprogramming keyless entry
I recently installed a new receiver module as my old one burnt up. I found an open 2 prong connector under the steering column that was taped into the wire cluster. I bent a paperclip into a U with small half-loops at the ends. I put it into the connector touching the prongs and then turned the key to ACC position. My truck immediately clicked the locks and then I hit any button on my first remote. My truck folowed with another clicking of the locks and then I repeated with the other remote and it clicked the locks ,also. Then I turned the key off and there was one last clicking of the door locks and then I removed my paperclip. Now everything works perfectly with both of my remotes! :-jammin
I located the grey connector & the 2 pins.
Then I shorted the 2 pins together while the key was in the ignition on acc. Nothing happened. Anyone have knowledge of what this means or what the problem can be?
I have the procedure to re-program (add a new remote to) the remote keyless entry on 1994 (and similar) F-Series. The procedure first involves jumping some pins at the "programming connector" so said to be located at the base of the steering column. Does anyone know which (of the many) connectors this refers to? My 1994 F-150 did the same thing. I wonder if electric locks were standard, but the keyless remote receiver was not. Maybe our trucks don't have the receiver installed. When I short out the grey programming connector, with the key in the "ON/ACC" position, the locks do not cycle to indicate I am in programming mode. It makes me wonder if there is even a receiver to program. Does anyone know where the receiver is located? |
Very few trucks of our era had remote keyless entry. Being equipped with power locks doesn't mean you have RKE.
I just did my 1994 F150, my old remote went bad. I followed the above explanation, and my locks did not work either. Upon looking around I found another connector taped to the harness for the security system. Just a bit to the right of the column. The one taped to the wires for the column is not the one you need. They look identical, but use the one to the far right, grey connector, 2 wires, with nothing plugged into it. Thanks guys for this process. Saved me a bunch of headaches!
connection for programming keyless remote
https://cimg4.ibsrv.net/gimg/www.for...a172eff5d8.jpg
Is this two pin connector without connection which is grey attached to black connector for programming the keyless remote? The connector above the upper right hand coner of the cream colored box with the writing on it. 1994 Ford F-150, XLT regular cab 2-door. Thanks, Iraa |
So how do I tell if my truck ever had remotes? It's the XLT Gold Edition. Seems to have everything else possible.
I took my VIN number to my local dealer and asked if my 1994 f-150 came factory equiped with remote keyless entry module. He looked it up in his computer and said that
ford had dropped all info on it -- probably due to age of truck. |
Thats because you are turning the key to acc first. You jump the pins and leave the clip in then you turn the key to on then use the new remote then turn key off and remove the clip.
All ford trucks from 1992 til current came with keyless entry.
