48 wiring to get it started /starter removal ?
hi
i have a 48 ford f1 all stock sat in a field for a long time wiring is shot and all switches shot starter seized how do i remove it ? i have got all the bolts out that i can see but will not come out have i missed one also i think it is 6 volt battery ,how do i hot wire ,to try to start it can i connect a 12v battery ? richard england thanks for any help guys |
Originally Posted by rustydicksimports
(Post 14910413)
hi
i have a 48 ford f1 all stock sat in a field for a long time wiring is shot and all switches shot starter seized how do i remove it ? i have got all the bolts out that i can see but will not come out have i missed one also i think it is 6 volt battery ,how do i hot wire ,to try to start it can i connect a 12v battery ? richard england thanks for any help guys To begin, if you have a 'stock' F1, it was equipped with either a flathead 6 or V8, both used the same starter and required the removal of only 2 bolts to remove the starter, they are indicated in the photo below. https://cimg6.ibsrv.net/gimg/www.for...beca08acf3.jpg The bolts do not need to be removed completely, simply backed out of the bell housing plate. If it's been sitting a long time, you may have to get the motor to turn some or beat and bang a bit to break it free from the flywheel. To answer your other question, yes you can start it with a 12v and bypass all the old wiring. Make sure you have a coil compatible with 12v, you can hook a temporary 'hot' wire from the battery to the coil (don't hook up until ready to fire up) then ground the battery to the motor and jump the starter from the battery. |
thanks
hi thanks for the help
I've never had the starter off of my 50', but that starter looks alot like the one on my 8N ford tractor, when the two bolts are removed on the tractor starter , the starter falls apart. I hope this is not the case with the truck starter.
i will watch out for that
thanks
i will be careful when removing rich |
They fall apart if your not careful pulling it out. Have a nut handy to put on one of the bolts once you get it out. Also there should be a strap of sorts from one of the oil pan bolts that helps hold up the end when it's installed. I had a hard time getting brushes for mine at Napa and asked them to check for the 8N. Sure enough ,the same. By the way welcome to FTE. Lots of experienced folks here willing to help. Also the starters don't pull straight out, you have to kinda wiggle it a bit to get the thing out .
Originally Posted by Skalywag
(Post 14910755)
Elmo |
Originally Posted by harleymsn
(Post 14910499)
https://cimg6.ibsrv.net/gimg/www.for...beca08acf3.jpg The bolts do not need to be removed completely, simply backed out of the bell housing plate. If it's been sitting a long time, you may have to get the motor to turn some or beat and bang a bit to break it free from the flywheel. 12V Vintage Torque Starter | Dennis Carpenter Ford Restoration Parts https://cimg2.ibsrv.net/gimg/www.for...816245d60e.jpg Or you can order a starter with the correct bendix. |
