Golden Fuel Systems v. BioFuels Technologies Vegistroke
Truck: 1997 Powerstroke 7.3l diesel. I'm having trouble deciding between these two kits: Golden Fuel Systems WVO kit & the BioFuels Technologies Vegistroke WVO kit. The Golden Fuel Systems kit costs $3,379.84 and comes with a heated tank. The BioFuels Technologies Vegistroke kit costs $3,495 without their $825-$1,225 heated tank. The forum posts about the BioFuels Technologies Vegistroke kit also mention that my year model truck has to be converted to electronic fuel injection to work with this kit which also will make the BioFuels Technologies Vegistroke kit more costly, where as the Golden Fuel Systems kit doesn't require conversion. Can someone with experience with either or both of these kits say whether the BioFuels Technologies Vegistroke kit is worth $1000+ more than the Golden Fuel Systems kit? Thanks in advance :)
Experience
I have owned both kits. I still have some Golden fuel valves that I plan to use on a 12 valve conversion. I'm a plant drive installer, but have personally installed grease car, Vegi stroke, plant drive and soon to be Golden fuel. The Cadillac of all systems is the Vegistroke. I'm supposing that you mean you'll have to use an electric fuel pump as opposed to the mechanical fuel pump??? If I remember correctly the 97 the injector pump has a low side that serves as the lift pump if that's what your talking about, it doesn't cost $1000 to do that swap. I may be way of so correct me if that's not it. I swapped a 97 over to plant drive for a guy 2 years ago. He can't get oil, so I bought the truck form him and i'll pick it up Thursday.
I've totally dissembled a Vegistroke before. I have 100k WVO miles on mine when I sold the truck. They are the best on the market by far. I've also had the GFS valves apart. They are good, but not near as robust as the BFT system. The install for the BFT will be much cleaner as well. There's no looped hoses and brackets/wires etc. The BFT is a much cleaner install. I'll pm you my number if you'd like to call. |
Thanks for your very informative post brobrad. I'm now leaning towards BFT. I don't know what the cost will be to switch over to an e-fuel system. From my research it's what needs to be done on an OBS 7.3 for it to be compatible with the Vegistroke kit. I may be wrong about this though. Please let me know if I am, I don't want to do anything unnecessary. The $1000 difference I was referring to was the difference in the price of the kits themselves. While both kits cost roughly $3,400, the GFS kit includes a heated fuel tank in the price, whereas BFT is asking $825-$1,225 for theirs on top of the $3,495 kit price, hence the $1,000 difference.
I have a GFS system on my 2000 power stroke....other than cleaning the outside of the tank, regular filter changes and a couple of gaskets, its a great set up. Charles installed mine nearly 100k ago, and it is still running smooth. I have no experience with any other systems, but can offer a testimonial on the quality of GFS....customer service is good to...
Mike In MN |
fuel change
I did look up the electric fuel pump change. It's not that big of a deal. It wouldn't be too hard to do, and it only consists of a fuel pump and regulator. Hope it all works out well. Keep us updated on what you do.
Originally Posted by brobrad
(Post 14834869)
Seller: Dave @ VeggieGarage because of upgrades & support offered. E-fuel conversion for OBS: Dave @ VeggieGarage Tank: GFS trekker tank because it's black (more heat from the sun), modular & the footprint better suits the space configuration needs of my bed. One Shot Filtration Unit: GFS because being able to filter & dewater on the road just seems awesome! I hope it works!!! 300 miles on WVO, so far so good! |
Originally Posted by 7.3dieselMike
(Post 15801360)
Kit: BFT VegeStroke because of the reputation.
Seller: Dave @ VeggieGarage because of upgrades & support offered. E-fuel conversion for OBS: Dave @ VeggieGarage Tank: GFS trekker tank because it's black (more heat from the sun), modular & the footprint better suits the space configuration needs of my bed. One Shot Filtration Unit: GFS because being able to filter & dewater on the road just seems awesome! I hope it works!!! 300 miles on WVO, so far so good! EXCELLENT choices. I went with a different setup recommended by skyskijason. My son could'nt afford the BFT system, but now they at half price so it is by far the best deal anywhere IMHO. |
(Post 15801360)
Kit: BFT VegiStroke V4 because of the reputation.
Seller: Dave @ VeggieGarage because of upgrades & support offered. E-fuel conversion for OBS: Dave @ VeggieGarage Tank: GFS trekker tank because it's black (more heat from the sun), modular & the footprint better suits the space configuration needs of my bed. There is no need for heat from the sun... But, if that tank fits where you need it, good deal. Is there a heat exchanger in the tank? If so, what is it? I hope it wasn't more than a quality custom alum tank. I have no love for anything GFS. I have removed and discarded several of their complete and total POS conversions over the years and frankly, my sleeve is soaked from providing their customers a shoulder to cry on after they wasted their money. :-roll
(Post 15801360)
(Post 15845023)
(Post 15845023)
(Post 15845023)
This DOES NOT WORK!!!!!! You CAN NOT dewater WVO with a filter or filters.
As I understand it, the Racor filter elements are treated with an aquaphobic coating which repels water.
(Post 15845023)
...just be sure you test the oil you are going to filter for water before using it.
Those filters are designed to separate free water from diesel fuel. They can not and will not 'remove water' from WVO. Completely different physics. MANY people have been misled into thinking they could dumpster dive and drive and had miserable (and expensive) road trips. If the oil passes HPT, Sandy Brae or similar for water, you don't need that expensive filter to remove particulates. Any cellulose (paper) element filter will plug up QUICKLY if you try to pump water/oil emulsion through it.
Take some diesel and water and shake it up in a bottle. Do the same with WVO and water. The difference is very obvious. I'm glad you've had a positive experience with Charles. I too spend a few hours per week talking to people about veggie and PSD stuff... His conversion for PSD's sucks and I've seen a few of his installs. I am not impressed. Is his in-tank HE still just a transmission cooler hanging in the tank with rubber hoses? :-huh That will fail and put coolant in your fuel eventually. Heating the whole tank is a dumb idea anyway. We just need to heat the fuel we are removing from the tank and warm the fuel in the tank enough so it can flow to the pick-up. But, GFS and everyone else on the market still try to heat the whole tank. It is very inefficient design that also potentially adds moisture to the tank as the hot oil cools and draws in humid air overnight. The Hot Shot is just a pump, filter and a box. Build the same thing yourself for a lot less. Does it still come with heater hoses? :-roll I hate to be so offensive, but I have literally removed and discarded several GFS systems from PSD's over the years and I also know a few people who wasted their money on the hot shot. |
(Post 15857151)
(Post 15855615)
Will you please expand on this. I am open to the opinions of those with more experience as I am relatively new to the WVO world. As I understand it, the Racor filter elements are treated with an aquaphobic coating which repels water. Now, chemistry and physics play a part in this and I am way oversimplifying. My chem major son may be able to shed some light. |
Jason, thank you for all your insight. I appreciate your experience & input on this matter. I really do want to do this the right way. So your posts are invaluable.
(Post 15857151)
Originally Posted by Racor
As fuel enters, it moves past the internal check valve then through the turbine centrifuge where it flows in a spiraling direction, spinning off large articulates and water droplets. Being heavier than fuel, they fall to the bottom of the collection bowl. Smaller water droplets bead-up along and on the sides of the internal components and on the surface of the Aquabloc II element. When heavy enough, they too fall into the high-capacity bowl to be drained as needed. Besides repelling water and tiny solids, asphaltenes, algae and rust are filtered from fuel by the Aquabloc II element. Because Aquabloc II elements are waterproof, they remain effective longer.
(Post 15857151)
One $10 filter lasts roughly 60 gallons. Even with diesel prices the way they are right now, that's a bargain.
(Post 15857151)
Interesting; what design do you prefer and why? Thanks. |
(Post 15882103)
One $10 filter lasts roughly 60 gallons. Even with diesel prices the way they are right now, that's a bargain. Thanks. |
Originally Posted by kirkharrod
(Post 15882573)
Huh? That's not good AT ALL. I filter thousands of gallons with the same $10 filter.
What kind of condition is the WVO in that you're getting? What's your settling / centrifuging process, if any? And which micron Aquabloc filters are you using? Thanks in advance. |
