fe 390 HELP!!!
I got a 75 f-250 and recently been having brake problems I did a full replacement as the rear were almost shot and front needed replaced and I tthen replaced master cylinder and power booster but after I replaced the booster it seems the engine now runs like crap. It refuses to idle and its running very rich I advances the timing and tuned the carb but to no avail. It seems no matter what I do it will not idle. I checked and rechecked all my vacume lines and ignition setup ( points coil etc) and all are fine. Anything would help I am compmetly stumped at this point. I have little experience in this field as this is my first fe 390 iv ever had the pleasure to deal with
The new booster appears to have a vacum leak. Unplug the vacum to the booster. If the engine idles that's the problem.
I did
Originally Posted by 69cj
(Post 14620172)
