Engine Stall declaration
1988 F250 Lariat Diesel
Engine stalls after releasing throttle pedal i was considering the temperature though after running for 40 minutes at idle in park not would not reach 192 degrees, there was word that pistons burn so i think a cylinder test would be appropriate Anyone with heads up on the situation The gauge on the dash is almost half using a Cen tech infrared thermometer https://cimg8.ibsrv.net/gimg/www.for...2b5db7491f.jpg The temperature at the thermostat housing and neck read between 178 and 183 https://cimg8.ibsrv.net/gimg/www.for...9e3f16d7c6.jpg 08/22/2014 F250 Lariat thermo temp 1988 F250 Temp gauge reading when accelerating at 2000 RPM for few the releasing the throttle the engine quits same scenario when driving and preparing to stop the engine will quit Video after letting it idle for 15 minutes it still has not reached temperature above 190 so have ot been able to check if thermostat opens A new thermostat calls for Part Number: 4399 Weight: 0.2 lbs Warranty: 1 YR Application: OE recommended temperature Notes: 195 degreesSeal included Gaskets Included: Yes Material: Stainless Steel, Copper Package Contents: Thermostat, Gasket Thermostat Opening Temperature (°F): 195 |
Did you replace the thermostat?
You listed its part number its ratings and specs but didn't read where you stated that you had put a new one in. |
Originally Posted by danr1
(Post 14606906)
You listed its part number its ratings and specs but didn't read where you stated that you had put a new one in. no i haven't replaced the thermostat i am doubting is the problem as it does not reach temp though will soon as i get a chance |
A busted thermostat can cause your truck not to warm up. When I bought my current truck, it wouldn't warm up for crap. Took the t-stat housing off and the old thermostat came out in three pieces. Lol.
engine stalling after releasing throttle has nothing to do with the engine temp. it is a sign of injector pump problems.
first thing to do is fire the engine up and get it warm. then shut it off and remove the fuel filter. drain it, and fill with ATF. put it back on and start the engine. let it idle for 30-45 seconds and shut off. then let it sit for at least 12 hours, 24 hours is better. the ATF will clean the crud off the inside of the injector pump. if this does not fix the stalling problem, you will probably need a new injector pump. |
