Ford Truck Enthusiasts Forums
-   1999 to 2016 Super Duty (http://www.ford-trucks.com/forums/forum30/)
-   -   5.4 Triton Upgrades? (http://www.ford-trucks.com/forums/1332112-5-4-triton-upgrades.html)
JMyers0901 08-23-2014 01:29 PM
I have installed a Banks monster exhaust system since my muffler rusted out. I was looking into other options because the truck can be a bit of a dog when towing even with the tow/haul mode (might just be because I'm used to towing with diesels at work).
I had to replace the passenger side exhaust manifold a while back because of the typical manifold leak issue, but I was looking into the torque tubes exhaust headers banks offers as well as their ram-air intake. They don't list the parts for the super duty though, just the f150. Since it is the same 5.4 engine, I was wondering if any of you know if these parts will work on the super duty too? The horsepower and torque should help when towing, and I may have to replace the drivers side exhaust manifold anyway, so these would be a better solution if they will work. Thanks in advance for your help!
seville009 08-23-2014 02:38 PM
I put a tuner on my 2006 5.4l. Is a noticable difference. I also have a 2011 6.2l, so I have something to compare it to.
Just got it in June, so I haven't tested it out with the plow on and 800lb of ballast yet - that's mainly what I use the 2006 for
RAYJAY! 08-23-2014 08:56 PM
which tuner did you go with?
seville009 08-24-2014 03:48 AM
Quote:
5 Star tuner
speakerfritz 08-24-2014 07:27 PM
change the gearing in the rear end..its cheaper, easier, and more bang for the buck.
