Stripped threads on rear main bearing cap
Working on sealing up my engine after installing a new rear main seal, I installed the oil pan only to discover that the threads for the oil pan bolts in the aluminum bearing cap are pretty stripped. They will hold a bit of torque, but not enough for my comfort.
Looking through my disassembly photos, I see that the metal there is pretty thin and open directly to the crankcase. (i. e. no drilling/helicoils) https://cimg9.ibsrv.net/gimg/www.for...9aa94e63f7.jpg I was hoping it was a little deeper and longer bolts might be able to grab some decent threads. Aside from disassembling everything again (Ug! Would add a week+ to this project, waiting for replacement gaskets, etc), any ideas on making sure this area stays sealed? ~Steve |
That is a MAJOR bummer. Visit your local machine shop guy and see if he has any suggestions.
I don't see why a helicoil wouldn't work. It's either that or tap to the next size and use larger studs. Or replace the retainer. Studs should be used in those two holes.
My experience with helicoils is all secondhand--but I was under the impression that the holes needed to be drilled out before the helicoil could be installed (and everything pulled out to do it.)
~Steve |
Just about any way you do it will require drilling or disassembly. You will need to remove the oil pan at least. You should be able to do it if you're careful. Remove all of the chips you can before you put it back together.
Another thing, you shouldn't torque oil pan bolts. Watch the gasket as you tighten it. You will see the gasket squish out slightly when it is tight enough. Use studs on the seal reatainer, like original. If you can get those nuts that tight, it will be fine. Use thread sealer on the studs, in the seal retainer. |
Sorry, I misunderstood the issue. On hand are many seal retainers. I can get one to you for not much, and within 3 days via priority mail. Mike
Originally Posted by charliemccraney
(Post 14596691)
Another thing, you shouldn't torque oil pan bolts. Watch the gasket as you tighten it. You will see the gasket squish out slightly when it is tight enough. Use studs on the seal reatainer, like original. If you can get those nuts that tight, it will be fine. Use thread sealer on the studs, in the seal retainer. I'm going to take my chances with the assembly as it is, knowing that I can still redo the whole thing with the engine back in the truck. The only real risk is a little oil on the clutch, which would suck, but I suspect I'll have weeping, if anything, and not the flood of oil I was seeing before. If I do need to re-do it, I'd pull the whole retainer and do the drilling on the bench to avoid any chance of contamination. ~Steve |
Make sure you put sealant on the studs/bolts on the retainer as since they go thru they themselves can be a source of a weepage.
Originally Posted by Y-Blockhead
(Post 14601062)
Do you, btw, happen to know the recommended torque for these? Couldn't find it in the manual. ~Steve |
Tap it to the next larger size.
Put in bigger bolts. |
Originally Posted by sseebart
(Post 14601154)
Good call--hadn't thought of that.
Do you, btw, happen to know the recommended torque for these? Couldn't find it in the manual. ~Steve I remember back a ways that someone installed metric studs/bolts. Don't remember what size but it was just slightly larger than the striped hole but smaller than the next SAE size. May hold you over until you have to drop the pan again.:-hair Good luck. |
The engine gods apparently want me to pull that pan off.
Snapped a bolt deep inside the timing cover while torquing the bolts down. Gotta pull the pan to get the cover off and fish out the broken end, so looks like I'll have an "opportunity" to drill the retainer and tap for studs. ~Steve |
You don't have to remove the pan for the timing cover. A timing cover kit includes the front portion of pan gasket.
Assuming you are using the correct length bolts and torquing them properly, you should replace all of those bolts because they will not snap if all is well. If one failed, then the rest may follow. Some of the timing cover bolts will contact the cylinder if they are too long. This can result in improperly torqued bolts and possibly severe engine damage. You should be able to thread them all the way in by hand and then torque them. If more than hand strength is required to thread them, find out why. Use thread sealer on the bolts that go through to the water jacket. Do not use RTV for this purpose. |
(Post 14606534)
(Post 14606534)
(Post 14606534)
Use thread sealer on the bolts that go through to the water jacket. Do not use RTV for this purpose. Many thanks for the tips. ~Steve |
Originally Posted by stuart1
(Post 14602164)
Put in bigger bolts. I noted, though, when I pulled the pan off, that the pan to retainer seal was weak, so glad I took the time to fix this. ~Steve |
