Ford Truck Enthusiasts Forums
-   Modular V8 (4.6L, 5.4L) (http://www.ford-trucks.com/forums/forum48/)
-   -   4.6 timing problems (http://www.ford-trucks.com/forums/1331257-4-6-timing-problems.html)
eddieburnsii 08-18-2014 02:03 PM
4.6 timing problems
Engine will only rotate 180 either way (by hand with a ratchet and socket) before something hits internally. Everything seems to be correct as far as I understand. I have attached pics of what I have. Any help will be greatly appreciated.
https://cimg5.ibsrv.net/gimg/www.for...3ea28b02cf.jpg
passenger side cam
https://cimg7.ibsrv.net/gimg/www.for...8f932e8481.jpg
driver side cam
https://cimg8.ibsrv.net/gimg/www.for...11411ba54a.jpg
crank gears marks are at the 6 o'clock position with the red links on chains lined up
https://cimg0.ibsrv.net/gimg/www.for...fb373bbfcc.jpg
overall pic
70f100longbed 08-18-2014 04:46 PM
Did you stretch out the chains like l=============l to make the marks? The links on either end are the ones to paint. What happened to make yo take it apart in the first place?
eddieburnsii 08-18-2014 05:04 PM
Yes the chains were stretched and marked l========l . It initially blew a spark plug out of the #3 cylinder. The head was removed to fix. After initially getting the timing incorrect and breaking 3 valves and bending one, my friend got a "new" used head for it. After sitting for awhile he is back to messing with it and is hoping to not repeat any mistakes.
70f100longbed 08-18-2014 07:23 PM
If its in time then something has to be on top of a piston or maybe a rod got bent and the piston skirt is hitting a crank counterweight. I know it's too late but there are repair kits for the stripped spark plug holes that don't require removing the head. Cal-van makes a very good kit and I have installed maybe 20 and have not had one come back.
