Ford Truck Enthusiasts Forums
-   Brakes, Steering, Suspension, Tires, & Wheels (http://www.ford-trucks.com/forums/forum64/)
-   -   advise on E350 rear leaf springs, Please. (http://www.ford-trucks.com/forums/1330731-advise-on-e350-rear-leaf-springs-please.html)
Keny1 08-15-2014 01:55 PM
Hi All I have a 2012 E350 with 5.4l V8 and tow a 30 ft flat bed trailer just 2 times a year. The Rear of the van is just a little too low with the trailer loaded. Would it help to add additional leafs to the rear leaf springs?
There are four leafs now, and the U bolts on the axle has 1 inch of extra thread on them. I'm thinking that I could add one or two extra leafs from another E350 to my spring set. Is this a good Idea or not.
Thanks in advance
Kenny Lyon
goldwingracingproject.info
ATS Junior 08-15-2014 02:43 PM
It's definitely not a bad idea! Adding a leaf will give you both a little more weight capacity and additional height. Are you dead set on using used leafs?
I would suggest putting in a long leaf leaf (rather than a short leaf) to get the most out of it.
-Junior
Keny1 08-15-2014 03:25 PM
Thanks Junior My thought was that the leaf spring from a junk yard would be the cheapest route. In 2008, Ford made a lot of changes to the E- series vans, Would you know how many year & model vans I could interchange leaf springs with? Could I use one the F - series leaf springs? Thanks Kenny
ATS Junior 08-16-2014 01:16 PM
I don't have my books with me right now so I can't really compare and contrast the difference steel gauge and lengths that were used. You might need to do some measuring and figure out what size leaf would fit best.
Torklift Sheryl 08-18-2014 01:56 PM
Quote:
You might consider Torklift’s StableLoad suspension upgrade. It will improve your overall ride quality and also eliminate the rear sag you mentioned. Its ability to engage/disengage with a quick-disconnect feature would be convenient for you since you only tow twice a year. :)
If you have a minute, see how it works on our website: LINK
Torklift Sheryl
Keny1 08-18-2014 02:57 PM
Torklift Sheryl
Hi Sheryl Thanks for the info on Torklift. I watched the video, looks good. Kenny
Torklift Sheryl 08-19-2014 01:22 PM
Quote:
Let me know if you need any help finding a dealer in your area. :)
Torklift Sheryl
sunuvabug 08-31-2014 05:13 PM
Sheryl, any dealers around Kitchener, Ontario Canada?
Torklift Sheryl 09-02-2014 06:44 PM
Quote:
Hello! It looks like the closest certified dealer to that area is Sicard RV.
Sicard RV
7526 HWY 20
Smithville, ON Canada L0R2A0
Phone: 905-957-3344
Website – LINK
Etrailer.com is also a certified online dealer that we recommend. Send me a PM if you need any help finding a specific product. :)
Torklift Sheryl
