Ford Truck Enthusiasts Forums
-   Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) (http://www.ford-trucks.com/forums/forum53/)
-   -   ford 1989 F350 7.5 flexplate (http://www.ford-trucks.com/forums/1330203-ford-1989-f350-7-5-flexplate.html)
lisagoud 08-12-2014 10:18 AM
what would be the most rugged crack resistant flexplate out there for extreme use ford 460 external balance to Ford c6
cbakker 08-13-2014 11:36 AM
Extreme use is pretty general. The stock flex plate can handle quite a bit of power. How built up is your C6? This is just as important as the amount of torque you will be putting to it.
lisagoud 08-13-2014 05:53 PM
motor is about 600 hp and mild build up on C6 for towing and 4x4 use ....mostly low end power.}> IU had heard good things asbout this one (any feedback out there?):
PRW 1846010 Xtreme Duty SFI-Rated External Balance 164 Teeth Steel Flexplate for Ford 429-460
