2004 Lincoln Navigator - 5.4 Intech - P2197 O2 Sensor Signal Biased/Stuck Lean (Bank 2 Sensor 1)
Hello Everyone,
Looking for some expert advice. Been fighting this lean condition on my 04' Navigator. Hoping I can get someone to isolate my issue as to which cylinder on the driver side is causing my issue. I know it can be a number of these: Oxygen (O2) or A/F ratio sensor or sensor heater malfunction Open or short in O2 sensor circuit (wiring, harness) Fuel pressure or fuel injector problem Faulty PCM Intake air or engine vacuum leaks Faulty fuel injector(s) Fuel pressure too high or too low PCV system leak/fault A/F sensor relay faulty MAF sensor malfunction ECT sensor malfunction Fuel pressure too low Fuel leak Air suction in air intake system Little background, has new plugs, cops, AIC cleaned, MAF cleaned, new cats, all new O2's, new DPFE, new air & fuel filter and new elbow at intake from PCV. Everything stock. Need someone to read the some of the live data posted below: Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.595 Short Term Fuel Trim Bank 2-Sensor 1(%)3.9 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.165 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)35.3 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)1.6 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)1.6 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 849 Vehicle Speed Sensor(km/h)0 Ignition Timing Advanece for #1 Cylinder(。)11.0 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)10.74 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.005 Short Term Fuel Trim Bank 1-Sensor 1(%)0.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.630 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.185 Short Term Fuel Trim Bank 2-Sensor 1(%)1.6 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.080 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)39.2 Engine Coolant Temperature(。C)89 Short Term Fuel Trim -Bank 1(%)-1.6 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-2.3 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 751 Vehicle Speed Sensor(km/h)0 Ignition Timing Advanece for #1 Cylinder(。)14.0 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)10.46 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.755 Short Term Fuel Trim Bank 1-Sensor 1(%)-0.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.635 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.585 Short Term Fuel Trim Bank 2-Sensor 1(%)-2.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.695 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)39.2 Engine Coolant Temperature(。C)89 Short Term Fuel Trim -Bank 1(%)-3.9 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-4.7 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 723 Vehicle Speed Sensor(km/h)4 Ignition Timing Advanece for #1 Cylinder(。)16.0 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)10.46 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.010 Short Term Fuel Trim Bank 1-Sensor 1(%)-0.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.500 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.190 Short Term Fuel Trim Bank 2-Sensor 1(%)-2.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.625 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)39.2 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)6.3 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)2.3 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 767 Vehicle Speed Sensor(km/h)5 Ignition Timing Advanece for #1 Cylinder(。)12.5 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)25.30 Absolute Throttle Position(%)22.0 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.880 Short Term Fuel Trim Bank 1-Sensor 1(%)-3.1 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.785 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.680 Short Term Fuel Trim Bank 2-Sensor 1(%)-5.5 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.775 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)65.1 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)1.6 Long Term Fuel Trim - Bank 1(%)-1.6 Short Term Fuel Trim -Bank 2(%)1.6 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 1310 Vehicle Speed Sensor(km/h)12 Ignition Timing Advanece for #1 Cylinder(。)25.0 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)24.52 Absolute Throttle Position(%)23.5 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.020 Short Term Fuel Trim Bank 1-Sensor 1(%)4.7 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.070 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.235 Short Term Fuel Trim Bank 2-Sensor 1(%)4.7 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.115 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)63.5 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)10.9 Long Term Fuel Trim - Bank 1(%)-1.6 Short Term Fuel Trim -Bank 2(%)3.1 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 1308 Vehicle Speed Sensor(km/h)19 Ignition Timing Advanece for #1 Cylinder(。)25.0 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)21.81 Absolute Throttle Position(%)22.0 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.750 Short Term Fuel Trim Bank 1-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.670 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.295 Short Term Fuel Trim Bank 2-Sensor 1(%)2.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.620 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)50.2 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)0.0 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-1.6 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 1091 Vehicle Speed Sensor(km/h)24 Ignition Timing Advanece for #1 Cylinder(。)26.5 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)15.67 Absolute Throttle Position(%)20.8 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.725 Short Term Fuel Trim Bank 1-Sensor 1(%)-1.6 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.545 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.365 Short Term Fuel Trim Bank 2-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.640 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)41.2 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-3.1 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)0.8 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 1017 Vehicle Speed Sensor(km/h)26 Ignition Timing Advanece for #1 Cylinder(。)17.0 Intake Air Temperature(。C)57 Air Flow Rate from Mass Air Flow(g/s)11.35 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.585 Short Term Fuel Trim Bank 1-Sensor 1(%)-3.9 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.505 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.615 Short Term Fuel Trim Bank 2-Sensor 1(%)-3.9 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.615 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)35.7 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-3.1 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-4.7 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 858 Vehicle Speed Sensor(km/h)21 Ignition Timing Advanece for #1 Cylinder(。)15.5 Intake Air Temperature(。C)56 Air Flow Rate from Mass Air Flow(g/s)10.46 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.835 Short Term Fuel Trim Bank 1-Sensor 1(%)-6.3 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.775 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.700 Short Term Fuel Trim Bank 2-Sensor 1(%)-7.8 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.780 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)37.3 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-8.6 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-11.7 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 820 Vehicle Speed Sensor(km/h)18 Ignition Timing Advanece for #1 Cylinder(。)15.5 Intake Air Temperature(。C)56 Air Flow Rate from Mass Air Flow(g/s)21.53 Absolute Throttle Position(%)23.5 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.010 Short Term Fuel Trim Bank 1-Sensor 1(%)-3.1 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.710 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.195 Short Term Fuel Trim Bank 2-Sensor 1(%)-4.7 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.140 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)48.6 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-2.3 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)0.8 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 1006 Vehicle Speed Sensor(km/h)21 Ignition Timing Advanece for #1 Cylinder(。)17.0 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)12.45 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.835 Short Term Fuel Trim Bank 1-Sensor 1(%)-2.3 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.735 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.680 Short Term Fuel Trim Bank 2-Sensor 1(%)-2.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.750 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)37.6 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)0.0 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-3.1 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 830 Vehicle Speed Sensor(km/h)17 Ignition Timing Advanece for #1 Cylinder(。)15.5 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)10.57 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.025 Short Term Fuel Trim Bank 1-Sensor 1(%)-0.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.690 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.535 Short Term Fuel Trim Bank 2-Sensor 1(%)-3.1 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.615 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)36.9 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-4.7 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-5.5 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 777 Vehicle Speed Sensor(km/h)16 Ignition Timing Advanece for #1 Cylinder(。)11.0 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)21.81 Absolute Throttle Position(%)23.5 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.840 Short Term Fuel Trim Bank 1-Sensor 1(%)-7.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.770 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.605 Short Term Fuel Trim Bank 2-Sensor 1(%)-10.2 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.750 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)63.1 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-1.6 Long Term Fuel Trim - Bank 1(%)-1.6 Short Term Fuel Trim -Bank 2(%)-1.6 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 1320 Vehicle Speed Sensor(km/h)21 Ignition Timing Advanece for #1 Cylinder(。)25.0 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)24.03 Absolute Throttle Position(%)20.0 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.820 Short Term Fuel Trim Bank 1-Sensor 1(%)1.6 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.145 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.320 Short Term Fuel Trim Bank 2-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.095 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)38.8 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)11.7 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)2.3 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 994 Vehicle Speed Sensor(km/h)24 Ignition Timing Advanece for #1 Cylinder(。)16.5 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)11.29 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.790 Short Term Fuel Trim Bank 1-Sensor 1(%)-0.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.640 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.635 Short Term Fuel Trim Bank 2-Sensor 1(%)-1.6 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.695 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)36.5 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)3.9 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-1.6 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 764 Vehicle Speed Sensor(km/h)12 Ignition Timing Advanece for #1 Cylinder(。)12.0 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)10.40 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.790 Short Term Fuel Trim Bank 1-Sensor 1(%)-3.9 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.725 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.660 Short Term Fuel Trim Bank 2-Sensor 1(%)-3.9 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.735 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)37.3 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-2.3 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-3.1 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 756 Vehicle Speed Sensor(km/h)0 Ignition Timing Advanece for #1 Cylinder(。)12.5 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)10.13 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.095 Short Term Fuel Trim Bank 1-Sensor 1(%)0.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.670 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.385 Short Term Fuel Trim Bank 2-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.680 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)37.3 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)0.8 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-0.8 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 757 Vehicle Speed Sensor(km/h)0 Ignition Timing Advanece for #1 Cylinder(。)13.0 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)10.24 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.030 Short Term Fuel Trim Bank 1-Sensor 1(%)0.8 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.670 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.195 Short Term Fuel Trim Bank 2-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.680 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)37.3 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)0.8 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-4.7 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 757 Vehicle Speed Sensor(km/h)0 Ignition Timing Advanece for #1 Cylinder(。)13.0 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)10.13 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.535 Short Term Fuel Trim Bank 1-Sensor 1(%)-3.1 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.670 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.540 Short Term Fuel Trim Bank 2-Sensor 1(%)-3.9 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.685 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)37.3 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-2.3 Long Term Fuel Trim - Bank 1(%)-3.1 Short Term Fuel Trim -Bank 2(%)-3.1 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 749 Vehicle Speed Sensor(km/h)0 Ignition Timing Advanece for #1 Cylinder(。)13.5 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)10.13 Absolute Throttle Position(%)19.6 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.800 Short Term Fuel Trim Bank 1-Sensor 1(%)-1.6 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.660 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.685 Short Term Fuel Trim Bank 2-Sensor 1(%)-3.9 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.785 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)78.8 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)4.7 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)3.1 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 1884 Vehicle Speed Sensor(km/h)17 Ignition Timing Advanece for #1 Cylinder(。)15.5 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)60.57 Absolute Throttle Position(%)33.7 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.040 Short Term Fuel Trim Bank 1-Sensor 1(%)5.5 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.470 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.525 Short Term Fuel Trim Bank 2-Sensor 1(%)2.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.105 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)71.0 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)0.8 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)1.6 Long Term Fuel Trim - Bank 2(%)0.0 Engine RPM(rpm) 2483 Vehicle Speed Sensor(km/h)36 Ignition Timing Advanece for #1 Cylinder(。)20.0 Intake Air Temperature(。C)55 Air Flow Rate from Mass Air Flow(g/s)68.66 Absolute Throttle Position(%)35.3 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.040 Short Term Fuel Trim Bank 1-Sensor 1(%)3.1 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.150 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.375 Short Term Fuel Trim Bank 2-Sensor 1(%)6.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.140 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)73.7 Engine Coolant Temperature(。C)89 Short Term Fuel Trim -Bank 1(%)-2.3 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)3.1 Long Term Fuel Trim - Bank 2(%)0.0 Engine RPM(rpm) 2325 Vehicle Speed Sensor(km/h)49 Ignition Timing Advanece for #1 Cylinder(。)16.5 Intake Air Temperature(。C)54 Air Flow Rate from Mass Air Flow(g/s)77.02 Absolute Throttle Position(%)36.1 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.450 Short Term Fuel Trim Bank 1-Sensor 1(%)-1.6 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.195 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.085 Short Term Fuel Trim Bank 2-Sensor 1(%)-0.8 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.100 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)71.0 Engine Coolant Temperature(。C)89 Short Term Fuel Trim -Bank 1(%)-1.6 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)-1.6 Long Term Fuel Trim - Bank 2(%)0.0 Engine RPM(rpm) 2520 Vehicle Speed Sensor(km/h)59 Ignition Timing Advanece for #1 Cylinder(。)19.5 Intake Air Temperature(。C)53 Air Flow Rate from Mass Air Flow(g/s)74.08 Absolute Throttle Position(%)33.7 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.780 Short Term Fuel Trim Bank 1-Sensor 1(%)-3.9 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.720 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.090 Short Term Fuel Trim Bank 2-Sensor 1(%)-1.6 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.105 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)68.6 Engine Coolant Temperature(。C)89 Short Term Fuel Trim -Bank 1(%)-3.1 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)-2.3 Long Term Fuel Trim - Bank 2(%)-1.6 Engine RPM(rpm) 2026 Vehicle Speed Sensor(km/h)65 Ignition Timing Advanece for #1 Cylinder(。)23.0 Intake Air Temperature(。C)51 Air Flow Rate from Mass Air Flow(g/s)52.04 Absolute Throttle Position(%)30.2 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.090 Short Term Fuel Trim Bank 1-Sensor 1(%)-1.6 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.690 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.140 Short Term Fuel Trim Bank 2-Sensor 1(%)-2.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.145 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Number of DTCs stored in this ECU 1 Fuel system 1 statusCL Fuel System 2 status-- Calculated LOAD Value(%)70.6 Engine Coolant Temperature(。C)90 Short Term Fuel Trim -Bank 1(%)-3.9 Long Term Fuel Trim - Bank 1(%)0.0 Short Term Fuel Trim -Bank 2(%)-3.9 Long Term Fuel Trim - Bank 2(%)-3.1 Engine RPM(rpm) 1833 Vehicle Speed Sensor(km/h)69 Ignition Timing Advanece for #1 Cylinder(。)29.0 Intake Air Temperature(。C)51 Air Flow Rate from Mass Air Flow(g/s)38.75 Absolute Throttle Position(%)26.3 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.090 Short Term Fuel Trim Bank 1-Sensor 1(%)-3.1 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.555 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.600 Short Term Fuel Trim Bank 2-Sensor 1(%)-6.3 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.700 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedOBDII Distance Travelled While MIL is Activated(Km)7 ---------------------- Thanks in Advance, Jay |
Guess there's no experts here??
Originally Posted by Kid Clean
(Post 14633914)
(Post 14633914)
Not sure if you noticed...but this is a voluntary source. To alloro's point, you can help future followers and edit out most of the data, having to page down through that overload of numbers. I bet if you PAID for that expertise, you'd get a quicker response. Ford dealers would probably take your money! There are many experts out here to help direct you to a service shop if necessary? |
Thanks for all they help everyone...I fixed the problem.
NEED HELP WITH 04 Lincoln Navigator Bank 1 lean bank 2
(Post 14649651)
Thank you very much. hope to hear more from you |
Le Hung, I fixed mine by getting rid of it for a Infiniti QX56 which runs perfect. No more Blue Oval junk here.
(Post 15119724)
Yup. That's the ticket. Buy a different vehicle. I'm sure he saved money by doing that vs getting a mechanic to take a look.
Originally Posted by brentkhack
(Post 15130897)
Originally Posted by alloro
(Post 15130906)
Perhaps there were other things wrong that he didn't mention. All together it might've been better for him to get a new vehicle with no issues. We'll never know! :)
P2195 and P2197
ok here what I found what wrong with my 04 Navigator. 1st there are PVC valve is bad, 2nd Fuel filter is bad,3rd the Vacumm eLbow craked cause Vacumm leak, 4th the 2 short small Tube along the EGR valve 1 of them is cracked lastly 1 coil voltage was leaking cause the rear speaker popping while driving or stopping at the light or stop side. I also check the MAF sensor and clean it out with Mass Sensor cleaner. Also threw in a set of plugs. That pretty much is. I can believe she run great. I had not see this many horse power from her since I got her. I thought about trade her in for the QX 56 or Armada,but not no more. So these are the basic you should look for be4 throw punch of $$$$ to the dealer ship. Now all my cylinders performing good. Brothers and sisters are working full speed together as they should.
(Post 15130943)
If that is the case then the kid doesn't know how to use the forum properly.
Originally Posted by Le Hung
(Post 15131050)
(Post 15133117)
Good job finding and fixing all of that. I'd say you saved yourself over $1,000 doing it yourself. :-X22
