Looking for a 400 in lower Mich.
im looking for an old 400 to rebuild in lower mich. My 77 has a 351 now, i want to swap to a 400,i know i can build my 351 into a 400 but i want to be able to drive it while im building a 400 this winter. THANKS:-X22
here a couple for sale in SE mich
Ford 400M and C6 transmission 1973 1974 1975 1976 1977 1978 1979 Ford truck parts |
Your sig says 351M, correct me if I'm wrong, but I thought the M shared bell housing pattern with the 429/460 as well? Any reason your not considering that engine?
Originally Posted by Chad149
(Post 14600259)
I have a couple. One needs rebuilding and one is on a stand with a fresh short block. HV Melling pump, mild RV cam, bored, Clevite 77 bearings. In west Michigan near Muskegon.
I can't imagine the weight being that big a factor, there is only about 150# difference between the 460 and the 400m.
As they say, there is no replacement for displacement........ |
Originally Posted by Toyman
(Post 14713048)
Now if they could just do the 30 packs with the bigger (16oz) pistons in stead of the 12oz ones.....
You can get 18 cylinder packs with tall boys... 288 cubic ounce displacement. My 30 cylinder, although smaller pistons displaces 540...
Who knew that Chrysler made a http://en.wikipedia.org/wiki/Chrysler_A57_multibank for tanks?
http://farm3.static.flickr.com/2293/...3342e6b255.jpg |
That should bolt into a Jeep then, plug and play right?
(Post 14713048)
Got a line on a good running 400, cammed, and new Pistons a few years ago. Edelbrock carb.
What's it worth to you? I might be buying the whole bronco |
(Post 14733884)
Originally Posted by zx3focus
(Post 14706167)
