Ford Truck Enthusiasts Forums
-   1978 - 1996 Big Bronco (http://www.ford-trucks.com/forums/forum44/)
-   -   computer problems (http://www.ford-trucks.com/forums/1329425-computer-problems.html)
muddigger1 08-07-2014 05:30 PM
computer problems
I have a 1994 ford bronco with a 5.0l automatic. I just attempted to put it on a computer to find out what the code is on my check engine light and the computer didnt even register. Could you please let me know how this can be fixed?
Black Ford XLT 08-07-2014 06:16 PM
Welcome to FTE, Your Bronco is a 1994 and I do believe its an obd 1 system . Your computer is in the bronco and what your using to find the codes is a scanner. Are you sure your scanner is obd 1 compatible ? obd 2 will not work on that year bronco. What symptoms are you having with your truck. TR
rla2005 08-07-2014 10:00 PM
X2... what were you using to check for codes?
jasoncarpenter1 08-08-2014 02:35 AM
x3 I specifically bought a OBD I and OBD II code reader. I went to auto zone, O Reilly and pep boys and only found one code reader for both. My 1994 Bronco is My only OBD I vehical.....
jowens1126 08-10-2014 12:58 PM
just ground the self test input to the battery and count the flashes of the check engine light.
If that doesnt work, you could have a bad EEC, which would explain your problems.
Ive seen at least a dozen 94 EEC's go out in the last few months, including 2 of mine.
