idle issues
95 302 either idles high or barely idles until warm. Once you get it running it will stay running. Any ideas? TPS?
Search how to test TPS. You can test before you buy one. Also IAC might be bad. You can test also. BTW did you check for codes???
The check engine light never came on so I assumed no codes. Thanks I will look that up.
Go here its a lot more active than the bronco section. If search or read the older threads you will find more info on your issues. BTW you probably have stored codes. No way to tell unless you scan it.
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums |
