Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (http://www.ford-trucks.com/forums/forum28/)
-   -   Why remove air pump? (http://www.ford-trucks.com/forums/1328911-why-remove-air-pump.html)
One Sock 08-04-2014 06:44 PM
I've seen a few threads about HOW to remove or gut the air pump (smog pump), but none of them really address the WHY. Has anyone done this and got better mpg, or a noticeable performance improvement?
eakermeld 08-04-2014 06:56 PM
If you have removed or gutted the cat, the air pump is pretty much jusr dead weight and a paracidic draw of power from the belt.
Shadow944795 08-04-2014 08:56 PM
Quote:
Agreed, once the old stock cats are removed or gutted out the air pump is useless and unless you live in an area where the smog Nazi's won't let you remove it and pass the test I say delete it and call it done. All you need is a shorter belt.
