Ford Truck Enthusiasts Forums
-   1994.5 - 1997 7.3L Power Stroke Diesel (http://www.ford-trucks.com/forums/forum170/)
-   -   1997 f350 crew cab 4x4 diesel fuel tanks capacity (http://www.ford-trucks.com/forums/1328769-1997-f350-crew-cab-4x4-diesel-fuel-tanks-capacity.html)
sand1 08-03-2014 09:42 PM
How many gallons is the front and back tank?
oldbird1965 08-03-2014 09:56 PM
19 front, 18.5 back.
HOOTs95PSD 08-04-2014 12:05 AM
Do we have options for a bigger rear tank?
FI460 08-04-2014 12:32 AM
Home
Bronco tank. Have to lose your spare.
MOOSE_MACHINE 08-04-2014 01:12 AM
There is also a 38 gallon for 87 pickups. http://www.amazon.com/gp/aw/d/B000C7...&robot_redir=1
HOOTs95PSD 08-04-2014 02:49 AM
Thanks for the links.. I saved them both. When I can get some down time on this truck it will be getting a bigger tank.
Would a fuel sender unit from the 88 truck hook right up to a 95's harness?
Awitte58 08-04-2014 07:40 AM
If you buy the 38 gallon bronco tank like shown in the first link above you can re-use your factory pickup/sending unit. You just have to modify it to be longer (the tank comes with the necessary hardware to extend it) and make some new slots for the tabs to hold it straight.
I did the 38 rear tank and now I can hold 60 gallons under the truck!
oldbird1965 08-04-2014 07:42 AM
I tried what I believe was a 80's sending unit and ended up running out of fuel with a half tank. I ended up doing what is written in the 'home' link above.
OldWoodsDiesel 08-04-2014 08:39 AM
i plan on doing this mod myself when rebuilding my truck.
Jim's write-up is quite clean, but is there really a need to extend the return line? i always like to dispense with extra work where possible :-)
MOOSE_MACHINE 08-04-2014 09:30 AM
Quote:
Originally Posted by OldWoodsDiesel (Post 14556662)
i plan on doing this mod myself when rebuilding my truck. Jim's write-up is quite clean, but is there really a need to extend the return line? i always like to dispense with extra work where possible :-)
I think you would get some air bubbles forming while the fuel drops I to the last half of the tank. Also you may get siphon issues if the return is left out of fuel
OldWoodsDiesel 08-04-2014 11:58 AM
i woudlnt be concerned with bubbles considering how the fuel sloshes around in there driving. back siphon is a good point, though!
oldbird1965 08-04-2014 12:30 PM
The hardest part of modding the sending unit is the insertion of the extended rod thru the plastic part is keeping everything lined up. My original sending unit was falling apart and when I tried it, it fell apart. Believe you me, a new one is not cheap and I sweated getting the rod thru.
DarkStarMedia 08-05-2014 03:43 PM
Quote:
Originally Posted by FI460 (Post 14556198)
Home
My spare has been fine.....
Richard
FI460 08-05-2014 04:40 PM
Quote:
Richard
Huh. Just repeating what I've read here.
Diesel_Brad 08-05-2014 04:48 PM
Quote:
It can still be mounted, just lower than stock
