Originally Posted by archtaan
(Post 14558419)
There should be some boot area you can get through on the firewall. Ive seen some people run it by the cowl and windshield/door area.
Originally Posted by fire240
(Post 14558439)
Yeah it is. Considering the 2 closest ones to me are downtown at the inner harbor or the one where that pic was taken. The one downtown has no parking close by and that one is easiest to get to by taking the suicide loop. ( AKA the Baltimore Beltway). Closer options are available including a mission BBQ.
Havent heard of them before Tim.
Originally Posted by Sparky83
(Post 14558457)
im hoping to try and sneek it through where the up fitter wires go through... but gotta find where they actually come out...
You could also use one of those. Splice on both ends. |
(Post 14558471)
The fitter wires that are factory installed come out by the brake pedal, off to the left.
Dont you have 4 wires there?
yup... but the trans temp gauges have 2 leads each... and im installing 2 of them... so ill be using all 4 wires...
1 lead is power and 1 is to the guage plus ground. Dont you only need to run 1 wire into the cab? I cant remember.
(Post 14558611)
*grabs his guitar and jumps on the stage and starts singin while strumin away...*
If I go crazy then will you still Call me Superman If I’m alive and well, will you be There a-holding my hand I’ll keep you by my side With my superhuman might Kryptonite :-headbang |
OK, guess I was way off.
I remembered 1 wire from the temp sender to gauge and 1 wire from the sender to ground. For the gauge inside its 1 to ground, 1 to 12v switched power, 1 to headlight switch, and 1 to constant power. That was only 1 wire through the firewall. Been a few years though. |
(Post 14558628)
(Post 14558652)
I take a walk around the world to ease my troubled mind.
Evening TIm,Devin and SHawn...
-THe Great |
hey clint...
