Originally Posted by fire240
(Post 14613311)
Have a good one guys. I'm heading out for the night.
Good morning Virginia.
Looks like a great day to finish detailing my SW. |
Good morning Virginia, happy soggy Tuesday! George, what's the SW?
1989 Ford Squire wagon, Pat.
Ah, I see. I had to explain to my 9 yr old daughter what a station wagon was a few weeks ago!!LOL
heyginney..
"Thank you. Now the gauge sat steady at 35 PSI while you were testing this sensor the whole time? 1.43 V is what you would generally see at a set pressure of about 35 psi, again those values appear to be just fine. I was looking mainly to see when this does bounce around and not steadily read, what the voltage would actually show because this will better help us determine what could be at fault. This vehicle should be putting out around 50-60 psi at idle and 35 psi does seem to be a little bit low but the voltage values you provided are what 35 PSI would show."
not the answer i was looking forward to reading... wrote them back asking how to check the voltage to the sensor. did get an answer.. will have to check it when i get home... |
Howdy folks.
Sounds like it might be a lift pump going out. Is that covered by your warranty? Might be time to add a FASS or airdog.
Originally Posted by archtaan
(Post 14614753)
lol been looking at them during lunch... some of the Airdog system just seem to be an assisting system like a prefilter before the lift pump.. others seem to replace the pump all together... |
Morning Virginia.
Originally Posted by Sparky83
(Post 14614757)
should be but dunno...
Hey Shaun.
Howdy Tim. How has your day been?
How's it going guys?
