(Post 14593159)
Adjust those mixture screws too.
will do, mixture screws to start at 1 1/2 turns from seat...Thanks |
OK, closed the secondary's off and reinstalled onto intake. set the curb idle screw to seat, turned it over a few times to fill bowls, started the truck, it started at about 1200 rpms and ran that way until the choke began to open, once it started opening the idle slowed until it was trying to die,
All vacuum lines into the carb and engine have been sealed off. stuffed rag back into the secondary bbl's and started the truck again, started about 1200 to 1400 rpms and stayed until i loosened the cloth up a little at which it slowed to about 600 rpms and stayed. Then I unplugged the vacuum plug from the line that comes from the bottom most part of the carb and could hear the loud hissing, the engine instantly started to slow down and in under 6 seconds it died. I stopped here to check in. going to let it cool down, and start it again without the cloth and see if the same vacuum line unplugged has the same result also, when it bagen to die in the first part of this post, I raised the linkage just a little to see if it would clear ou, it did for just a sec but sounded starved and slowed again with linkage still held in place. |
OK, started the truck again, this time without cloth in the secondary's, choke nearly closed.
Truck started up at around 1900 rpms and kept running, I unplugged the same vacuum plug to the line on bottom back of carb and this time it sped up another 300 or 400 rpms.. letting it cool down again to try something else |
Originally Posted by Kyre Searcher
(Post 14593389)
All vacuum lines into the carb and engine have been sealed off. stuffed rag back into the secondary bbl's and started the truck again, started about 1200 to 1400 rpms and stayed until i loosened the cloth up a little at which it slowed to about 600 rpms and stayed. Then I unplugged the vacuum plug from the line that comes from the bottom most part of the carb and could hear the loud hissing, the engine instantly started to slow down and in under 6 seconds it died. I stopped here to check in. going to let it cool down, and start it again without the cloth and see if the same vacuum line unplugged has the same result also, when it bagen to die in the first part of this post, I raised the linkage just a little to see if it would clear ou, it did for just a sec but sounded starved and slowed again with linkage still held in place. i am so lost without vacuum gauge and fuel pressure gauge:: i would just do compression check and examine the spark plugs(i hate more than anyone to remove very glued in spark plugs and risk having something happen (or those dirty specks of dust/rocks/rust that love to sit in the park plug wells and jump into the cylinder first chance they get)with the head or spark or ?? who knows what when you remove the plugs.. I make it a habit of not touching the spark plugs if i can possibly avoid it, ever. and yet for me to type compression check to you, you can imagine how lost i am without vacuum gauge readings and fuel pressure check) i feel horrible suggesting things to you, and they haven't fixed the problem so far :( |
Originally Posted by Patrick Omally
(Post 14593439)
i am lost without vacuum gauge readings and without fuel pressure check? clogged fuel filter? i am tired of reading this thread, so i can only imagine how frustrated you must be trying to fix..
i am so lost without vacuum gauge and fuel pressure gauge:: i would just do compression check and examine the spark plugs(i hate more than anyone to remove very glued in spark plugs and risk having something happen (or those dirty specks of dust/rocks/rust that love to sit in the park plug wells and jump into the cylinder first chance they get)with the head or spark or ?? who knows what when you remove the plugs.. I make it a habit of not touching the spark plugs if i can possibly avoid it, ever. and yet for me to type compression check to you, you can imagine how lost i am without vacuum gauge readings and fuel pressure check) i feel horrible suggesting things to you, and they haven't fixed the problem so far :( But question, if the fuel filter were clogged or partially clogged, could that make it run rich? running rich, im assuming that means more gas than air, so the filter clog imo would have the opposite affect. |
I've sworn to sit aside on this and let someone else lead, but I can't because I disagree with the change of plans. Let's continue on this tack. You've just proven some things about the situation.
(Post 14593475)
i realize it can be hard for two people to suggest things, and i would prefer you to do the suggesting, because above else i want this fixed |
(Post 14593471)
Dont feel horrible, I very much appreciate everything you have suggested.
(Post 14593491)
i nominate you thread leader!
(Post 14593500)
Nope. Both Dave and Jim have been helping along the lines of finding out if it is lean or rich, under what conditions, and then why. I believe you suggested pulling the vacuum cap to find out if it is rich or lean, which was a good idea. Now we need someone to consolidate what we've learned and ask the next question. I'm just reading the mail.
Could it be any help to temporarily remove the fuel filter from the equation? |
(Post 14593495)
well rpm increased when the choke was closed........... when the choke is closed it should be naturally rich
Choke closed is getting more signal to the boosters. Gary can have the helm, but I suggest opening the plates until it is well into the transfer slots. The truck should have to run then. |
It slowed down and died when he pulled a vacuum line off. I believe this is confirmation what we already know, he is lean. I do not know what his aversion is to those two mixture screws, but he simply refuses to move them out some.
(Post 14593504)
Let me ask which port under the carb did you open? The PCV or the one under the choke housing? |
are all 8 cylinders sparking?? a spark plug inline tester would be great here
it could have even produced the problem in the first place |
Originally Posted by ArdWrknTrk
(Post 14593510)
Leave the filter.
Let me ask which port under the carb did you open? The PCV or the one under the choke housing? I opened the port on the carb that goes to the pcv |
