Another 4.2L leaky gasket victim
just pulled the upper and lower intake manifold gaskets off my 96 F150 with the 4.2 V6 EFI. i unfortunately managed to break both the little square plastic bushings that hold the IMRC rods to the manifold. do i have to replace both IMRC's or can i buy the little bushings? need help ASAP thanks :-huh :-drink
In case you're still needing an answer to this question, Dorman does make a kit that has new plastic bushings that should be what you need. Here is a link to RockAuto that has the pictures and part number for the kit:
More Information for DORMAN 47099 If I'm answering this too late, I apologize. Hopefully this info will help someone searching for this same issue in the future. :-drink |
