Ford Truck Enthusiasts Forums
-   1994.5 - 1997 7.3L Power Stroke Diesel (http://www.ford-trucks.com/forums/forum170/)
-   -   boost (http://www.ford-trucks.com/forums/1324664-boost.html)
red 1997 powerstroke 07-10-2014 07:27 PM
boost
hi i was wondering if some one can tell what kind of boost my 97 f 350 should produce it has rose wood stage 2 injectors banks inner cooler d66 beans turbo t 500 oil pump and dp tuner when stepping on it it will get close to 30 psi then for some reason it drops 10 psi down to 20 and then my egts start climbing any body no why it be doing this? is this normal? i contacted dp tunner and they said that boost is to low and its causeing my egt readings
oldbird1965 07-10-2014 10:24 PM
Boost sounds about right but when it drops to 20 I'm wondering if the boot off the turbo is collapsing?
red 1997 powerstroke 07-10-2014 10:58 PM
boost
that is a good posability u mean the intake boot off the air cleaner? as soon as the boost drop the egts start climbing so the boost shouldnt drop that much then right?
MOOSE_MACHINE 07-11-2014 12:08 AM
Quote:
Do you still have the orange boot from the intake side of the turbo
red 1997 powerstroke 07-11-2014 12:25 AM
yes i do and stock air box 2
fordman67 07-11-2014 01:20 AM
Um...you need to get a riffraff intake boot and a 6637 style intake.the stock box was leak prone as well as the boot.
MOOSE_MACHINE 07-11-2014 08:08 AM
Quote:
As well as that I seem to recall reading that the orange boot can collapse on higher boost levels
red 1997 powerstroke 07-11-2014 10:54 AM
boost
ok is there way i check to see if thats what it is, this wouldnt be a de fuel issue because the egts are getting hot right?
MOOSE_MACHINE 07-11-2014 02:44 PM
Quote:
I don't think you could. You would have to see iti a loss of boost situation which I do t think you'll see parked or find anyone willing to watch while moving.
fordman67 07-11-2014 02:53 PM
Just pull the orange boot off and take a short test driven.
Personally the orange boot is a liability regardless.they were junk new.ford sold a kit that retrofitted obs to SD style intake because it was failure prone!
red 1997 powerstroke 07-12-2014 09:18 PM
boost
so ran the truck with orange boot off ran great boost never droped so what kind of intake should i get is the riff raff one mentioned earlier on this thread a good option? thanks luke
MOOSE_MACHINE 07-12-2014 09:41 PM
Quote:
Probably one of the best. He has a great price on the filter but remember to get the turbo boot as well
oldbird1965 07-12-2014 10:56 PM
High EGT's will not defuel but high rpm's will.
