Cab clearance lights
Opinion: What is best? All 5 lights evenly spaced or outer 2 with 3 in center?
Question: What is standard mounting measurements for both? (I don't want to guess) |
If your installing them look at some picks and decide what you like best. I personally like the evened out
Evenly spaced. Not sure on measurements.
I just put some on my sons Bronco evenly spaced. They look good. But most trucks you see the side markers with the three center clearance.
I kinda like the evenly spaced. But more opinions the better. Thanks |
The stock lights were evenly spaced from the factory. The newer truck have them spaced out unevenly, but the older ones like we have were all spaced the same from the factory. If I recall correctly when I put them on my old truck I spaced them on 12" centers and 1 5/8" back from the drip rail. Here is a thread that has the how-to. Page 2 has the measurements.
Evenly spaced for sure
So far these are what I have got from scouring internet for standard light placement:
3 Lights centered Lights Centered |
Go with even spacing. 3-in-the-center makes me think chevy...
Agreed. Even spacing it us. So I have read that there is a factory connector in passenger kick panel for the lights. True?
And I assume everyone's follows the arch of cab, not in straight line?
Originally Posted by jle70
(Post 14495602)
Thanks. Now I just need to get them on. :-)
(Post 14499146)
Evenly spaced like the factory did it
https://www.ford-trucks.com/forums/1...ab-lights.html |
