Gonna ride great. Love seeing home done trucks with out of the ordinary methods and parts. :-X22
Wow this is really come along!
EZ wiring harness
https://i207.photobucket.com/albums/...psdhwpvsjv.jpg exahust is "done" https://i207.photobucket.com/albums/...psp1qj3kwj.jpg https://i207.photobucket.com/albums/...psja1rpnln.jpg https://i207.photobucket.com/albums/...ps1p4sg3rn.jpg just working on the front end, made headlight boxes, makign brackets ot hold the grill is tkaing forever. hopefully hav eit done today. |
Are you making a custom dash and gauge cluster?
no stock dash, cluster..maybe. The only thing that works(ed) was the tach. I might just make my own panel. I use my gps for a speedo since the plastic gear is stripped in the trans, and im not spending 400 bucks on an actual GPS speedo. I do need a tach, will probably go aftermarket. I would like to fit as many gauges as i can in the stock opening, might be hard though.
Does the rear end have a VSS? If it does you could use the factory speedo I bet
it does indeed, thanks for that. an auto meter programmable speedo will work great!
https://i207.photobucket.com/albums/...pswdgvfbcs.jpg https://i207.photobucket.com/albums/...pssyxovstq.jpg https://i207.photobucket.com/albums/...ps3f28czfw.jpg almsot done prewiring my dash, ordering some 4'x25 either 1/8 or 1.4" rubber roll to cut up and screw to my floor. using black RTV to seal all gaps. shoudl help with interior comfort. |
You're welcome! I still think a custom aluminum diamond plate dash would be killer... Then all you need is a couple of hole saws for gauges and a couple of recessed boxes for like a radio and heater controls
i shoulda recessed the filler some more but oh well. shes sturdy.
https://i207.photobucket.com/albums/...psqyy9ds4w.jpg https://i207.photobucket.com/albums/...pscjhnen5g.jpg Got a bunch of stuff done yesterday, gotta list it all out so its out of my mental checklist fuel filler minus paint wiper wiring wire linkage bushings organized the headlight wiring drained ATF from zf5. need to reseal the PTO plates changed out a bulb in my boost gauge. hooked up my dome return to the light switch wiper, ignition and headlampo switches installed in their respective bracket put another pushbutton on my switch panel, and a blue light for high beam indication finished wiring for the tailights, hazards and turn signals work. made a pig tail for my aux reverse lamps put the correct shock bolts in need to clean my e pump pickup screen, collected some crud from the tank, that bowl is on there tiight horn install kit came in so i can put the tilt column in along with my wood grant wheel hooked up my blower wiring inside the cab, just need to make my relay pack under the hood installed megafuses for the alternator and glowplugs need to make one more bracket for exhaust tip and paint it black. Im always happy when the electrical works as it should. Its always a surprise lol. Hopefully my HVAC works! and sounds! https://www.youtube.com/watch?v=POb6...ature=youtu.be |
Holy cow lol I was not expecting that!!!
Looks kinda cool definitely different, time for blacked out bullnose grille!:-X06 |
Originally Posted by 85F350IDI
(Post 15272582)
well honestly i think it would with litte modification i mean everything on that truck is custom (well alotta stuff is) theres a very miniscule difference b/t the bullnose and bricknose trucks, how ever its up to him whether or not he gets anything like such done, i think itd be neat but then again im in love w/ them bullnose trucks :-down:-tap:-tap
