Ever had a day where your feeling stupid?
Well today was my day. Over torqued a small bolt and now
I get to remove it. You know that little bolt that holds the turbo oil feed line onto the top of the oil filter housing? Well you know the one I broke. Set the torque wrench too high and you know the story. :-X19 So tomorrow I get the battery for the drill all charged up and get the reverse twist bits out and remove that little sucker from it hole. I am taking the night off and will chill. Also the cats were bouncing off the walls and so I went in to keep them calm. And once I was in they calmed right down. Oh well. Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
About every other day for me.lol. The off days my wife let's me know.
Hey Sean , I have been known not to be the brightest light bulb on the tree , and Eric is right My wife will dam sure not to let that get by her:D so I turn it on her some times I get Smart every other Day:-wink. Yea the Dog House still has a heater in it
Step or page two on the stupid mistake.
Well today I start to fix my little mess. I talked to Josh on the phone for a while to calm my self down some on the drive over to Ford to pickup an oil cooker gasket set. Thought I could get away with just pulling the filter and upper oil cooler housing. But one little bolt said NO. It's under the intake and I don't see any way to get at it. So fast-forward. Turbo is out and surprisingly it was not as bad as I thought it was going to be. I did find I need to work on some of the harness do to oil making it mushy in a few places. Anyone got an easy way to clean it? I did do the tricks DieselTechRon talked about and sprayed the clamps on the turbo with some penetrating oil also hit the turbo pedestal bolts. Worked like a charm. One thing that did not work that he shows is removing the alt wire from the battery clamp and flipping the harness back over the engine so it not in the way. I found that I would also have to unhook the A/C clutch and a pressure switch. Then I would have to work the cabling back around the A/C compressor and after that I can flop it over. Not going to happen unless in the daylight I see something I missed by the light of the devious device called the most appropriate name of Trubble-Light. What a pain Never where you need it shining or not shining (in the eyes) also the cord won't settle so that you can turn it just so. You get the idea. The only nice thing it's one of the CFL units I got from Boeing Surplus years ago. So not metal housing that gets blazing hot. So tomorrow aka Later today I pull the intake and hope that the gaskets are not old and crusty. I will clean the intake soot. Then clean the muck in the valley. Nasty mess from a mis-pour of oil into the crankcase. Then fix the broken bolt and back together it goes. I can see a CCV mod in the future. Depending on how things go I may pull the #8 and do a little polishing of the spool valves just to get that out of the way. If I do you can bet that there will be a video of the IDS power balance at cold start after that is done. One photo tonight and a thought. Don't break that bolt. https://cimg5.ibsrv.net/gimg/www.for...e5edb62f4b.jpg One other thing I thought I should mention. With the EGR system off the valve sure is nice and clean. Just a little bit of dust on the one side. It's been in for at least 7K miles. Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
Ouch...well it happens Sean. If I'd have seen this earlier I'd have told you to take a small screwdriver or punch and try tapping the offending screw counterclockwise to see if it would just screw out. Sometimes you can catch an edge where a thread breaks and use that edge to tap on and the screw comes right out.
The little lock nuts that are all over the engine are 6mm IIRC and you can get a package of 10 at lowes for really cheap. If the one on the GPCM you are missing is the bottom of the bracket then leave it off anyway. It's just a PIA |
Originally Posted by npccpartsman
(Post 14485788)
The little lock nuts that are all over the engine are 6mm IIRC and you can get a package of 10 at lowes for really cheap. If the one on the GPCM you are missing is the bottom of the bracket then leave it off anyway. It's just a PIA it stuck. How much do you want to bet once I have it out on the bench it will back right out no problem? Well at least I can install the EGR cooler I have sitting in the box and clean the intake of all that nasty soot goo. Once I do the CCV mod to a filter can how long for the intake to dry out do you think? Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
Originally Posted by Yahiko
(Post 14486306)
Thanks and yep it the bottom one. I even hit the bolt with a reverse bit and
it stuck. How much do you want to bet once I have it out on the bench it will back right out no problem? Well at least I can install the EGR cooler I have sitting in the box and clean the intake of all that nasty soot goo. Once I do the CCV mod to a filter can how long for the intake to dry out do you think? Sean https://www.ford-trucks.com/forums/p...ctureid=149188 It doesn't take long for the CAC to clear out. Depends on how much boost you put through it.....}> |
Only on the days that I wake up.
Sean: just a tip on the trouble light: I picked up this 3 pack of LED lamps that strap over your head at Costco for $10. Probably one of the neater things since I picked up the Ridgid compact drill driver set (lifetime warranty on everything, including all wearable items) with the LED lights built into them. On the lamps you strap on your head: I've crawled under houses, walked across dark camp grounds, read books late at night and yes even worked under and over engines -- with both hands free (and man that little impact gun works suweet on machinery) :-X22.
By the way, Home Depot lowered the price on the set I got: 1 compact 2-speed drill, 1 compact impact driver, 2 18V Li batts, charger, radio and carry bag for $179 (if you"find" a Lowes 10% off coupon they'll take that off too }>). You have to register the tools for the lifetime warranty, but you'll never buy another battery :-X03. Bonus round for me is I bought an 18V Ridgid cordless combo set (NiCad) of full size tools 11 years ago when HD 1st came out with them -- have gotten several free batteries, but the way cool thing is: the new batteries interchange with the old; any tool works with any battery! Not too many manufacturers do that! As I understand it, Milwaukee makes the Ridgid stuff for Home Depot... |
Well I have an update and one PISS-OFF item. Seems that someone that
was in to the engine used RTV to seal the heater outlet vs replacing that stupid O-ring. Once I got my hands down around and felt the RTV I was able to break it free and then remove it. I was surprised that the intake was not chocked with oil soaked soot. But then again my EGR is turned off. The water in the soak tank looked like very strong coffee and I could not see the intake at the bottom. https://cimg2.ibsrv.net/gimg/www.for...c7ffce16b3.jpg https://cimg3.ibsrv.net/gimg/www.for...e174a4b9a3.jpg Right now I am doing some cleaning and will pull the top of the oil filter and cooler housing once it cools off a bit. https://cimg5.ibsrv.net/gimg/www.for...36a1b31d1a.jpg https://cimg6.ibsrv.net/gimg/www.for...ef6340b086.jpg EDIT : The reason it looks wet I had already sprayed it with the Simple Green BTW I am using the Aviation grade Simple Green to do the cleaning. Then after the soak I will hit the intake with the pressure washer to plow any thing that is left out. Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
yep--today-not working on the truck but was updating software on a buddies fish finder today and I was trying to be careful and not fall out of the boat (was in his garage) I slipped backwards and did a header into the console--he asked if I was drunk lol. |
Originally Posted by KDAVID1
(Post 14487015)
(Post 14487015)
yep--today-not working on the truck but was updating software on a buddies fish finder today and I was trying to be careful and not fall out of the boat (was in his garage) I slipped backwards and did a header into the console--he asked if I was drunk lol. Anyway UPDATE. UPDATE https://cimg6.ibsrv.net/gimg/www.for...989b181930.jpg The little ratbasterd is out of there. Got it in the drill press and used a die grinder burr to start my hole then moved up a drill bit. I stepped up one more size and thought it looks good to back onto the bench and tapped in an easy-out and took a small wrench and gave it a turn. Odd I thought I had it and started to pull on the easy-out, It was tight so I gave it a 2nd turn and watched closely and the bolt end was moving. I have a video I will share later tonight when I took my borescope and shot some video of the inside of the coolant side of the oil cooler. Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
(Post 14487015)
Originally Posted by 9228.bobcat
(Post 14487133)
Well we're you? Lol
