99 F150 ABS activates when shouldn't
Hi guys,
I am experiencing a situation about 50% of the time when driving and apply the brakes to slow down and stop. When I’ve slowed down to about 5 mph, the ABS will activate until I stop completely. No slick road surface or sewer covers. No turning. Just driving straight on dry pavement. Any ideas what is going on and how I need to approach repairing this annoying situation? Thanks for any thoughts. Lou |
Is the light comming on or can you feel it kick in.
Originally Posted by Marty N Debbie Sapp
(Post 14483831)
Sounds like you may have one bad wheel speed sensor and/or wiring. Does it have 4 wheel ABS?
Sent from Nexus 4. IB AutoGroup |
Originally Posted by 73fan
(Post 14484084)
It would be unusual for a 99 to be RABS. Most likely, it's 4WABS. Look at your front spindles to see if there's a wiring harness going to each of them.
Most likely, you have a dirty/corroded sensor, a cracked tone ring, a damaged wire harness or a worn front wheel bearing that's causing an erratic signal from one of the sensors. |
Originally Posted by projectSHO89
(Post 14484858)
You will need an assistant to do one of the tasks.
Select a safe area such as a gravel-covered drive or lot. Driving at about 10 mph, apply the brakes sharply so as to cause either one of the front or both of the rears to lock up. Repeat several times observing to see if one front wheel (or both rear wheels) locks consistently. The front wheel that locks indicates a sensor problem on that side or, if both rear wheels lock, the problem will be with the rear diff sensor. |
All you have to do is look. I saw the wiring for the front wheel sensors and, I'm assuming, the rear wheel sensor also. Is it located at/in the differential? I saw a connector at the top of the differential housing. is that the sensor location or is it somewhere else on/in the rear end?
Originally Posted by FordLou
(Post 14485195)
...............and, I'm assuming, the rear wheel sensor also. Is it located at/in the differential? I saw a connector at the top of the differential housing. is that the sensor location or is it somewhere else on/in the rear end?
(Post 14485195)
The 99 only the single sensor on top and the ring gear inside for the rear wheels. Check the sensor first since getting to the ring gear is messy and smelly.
Is there a way to check the sensors using a DMM set to ohms? Saw a video on Youtube showing unplugging the sensor from the harness, attaching a DMM, spinning the wheel and checking for resistance and resistance changes (it was on a 2002 and he got 535 ohms on the good replacement and 1 on the old bad one he changed out). His ABS light had been on, though, and mine hasn't. Don't know if that means a different issue in my case.
Set the multimeter to VAC and look for several volts when the wheel spins. The resistance check is done when the wheel is stationary and will tell whether or not he sensor is ope (usual) or shorted (unlikely).
(Post 14488513)
