Help ID my Truck
Hi Guys new to the site found it in a search for info on my (what i believe is) 1949 v8 F-? series truck. I really would like to ID it as I'm not sure what F it is from what i can gather so far maybe F4 or 5, The only numbers I can find is LH side rail just behind the bumper (7R8T 5014)& LH top of fire wall (7C or G81 1854) & RH in front of battery box (9G12878*). no plate on glove box lid. Ill post the pics any help would be gr8 :) Thanks Tony
https://cimg8.ibsrv.net/gimg/www.for...a72ab22248.jpg https://cimg0.ibsrv.net/gimg/www.for...f4d2a3e626.jpg https://cimg1.ibsrv.net/gimg/www.for...334f6e4d0a.jpg https://cimg2.ibsrv.net/gimg/www.for...a9727f8756.jpg https://cimg3.ibsrv.net/gimg/www.for...e1cb3428a1.jpg |
I believe that would be an f-4. Does it have a single or double wall frame?
Thanks Nick , Yes it is double rail up to the front of the rear spring hanger
None of those numbers id the year. Single speed rear is F4 or 5, so what size wheels do you have?
Any vin no's on the firewall? |
Originally Posted by Tonzfseries
(Post 14480939)
single speed rear on 750-20" tyres
Being an Aussie truck, I wonder if it uses the Canadian system of serial numbers? Is it RHD?
BTW, welcome to the forum! |
Looks an awful lot like an F-5 to me. Welcome to the forum.
We seem to have a good contingent of Aussies on this site now. That great.
Welcome to FTE! What are your plans for it? |
I can tell you the 7R8T means a 158" wheelbase for a F-4/5/6 truck.
It should have a Canadian vin number on the left side frame rail in the engine compartment and under the cab just after the transmission crossmember on the same side. I assume its also missing the tag plate on the top center of the firewall in the engine compartment. There should also be a plate beside the starter solenoid on the right hand on the firewall. Can't quite remember what is exactly on this one but might help narrow it down. |
(Post 14480985)
The Canada connection, hmmm - that front marker light does look like Mercury |
Looks like a really nice solid truck.
Thanks for the welcome guys :)
It is a solid truck very little rust to good to pass up. Yes Ross it is RH drive & unfortunately Nathan it is missing all the tags, i have had a wire brush on the left hand rail but found nothing.The cab is coming off so i will be looking for the number under the cab. Only thing as in parts so far on the list , not that i have look hard yet is a left hand outside door handle, right hand bonnet hinge, the plastic grill centre of dash, rubber kit, dash switchers & brake lines under g/box are rusted but I'm sure that list will get longer as it get broken down. https://cimg8.ibsrv.net/gimg/www.for...5ff939cd1d.jpg |
Everything you have listed there can be bought new mate, I bought all the same parts plus a heap more for my F3. Feel free to email me at aussiecowboy@gmail.com. I still have quite a few bits floating around. Bring the parts in direct from the states, DO NOT buy in Aus unless you're willing to mortgage your house!
Originally Posted by Harrier
(Post 14481079)
