1999 f250 5.4 no spark
Just got the truck starts when cold once driven for an hour or so it wouldnt start wait an hour starts did that for 3 weeks now wont start at all I changed crank sensor still no spark when i did crank sensor noticed wirers where cut and plug must of been replaced if its not crank sensor where do i go next plz help :-X16
how did you verify the no spark at a spark plug or coil. how did you find that the crank sensor was at fault did you test more than one coil. how fast doe the engine crank and get any codes pulled from the truck.
My next move would be the cam sensor,,,
A cam sensor will not cause a "no spark" condition. At worse, it will cause multiple starting attempts as the PCM guesses at injector timing in the absence of a valid cam signal.
Originally Posted by projectSHO89
(Post 14488072)
Since a cam sensor won't cause a solid "no start" anyway, it doesn't much matter.
(Post 14488545)
Im having this same issue..Need your help plz..
