Ford Truck Enthusiasts Forums
-   1997 - 2003 F150 (http://www.ford-trucks.com/forums/forum25/)
-   -   Ring Gear Size (http://www.ford-trucks.com/forums/1322019-ring-gear-size.html)
bluecobra 06-25-2014 10:57 AM
Ring Gear Size
I have an 2001 F-150-5.4-4wd-H-9 diff.
Looking on RA to buy rear axle bearings. How can I tell if the ring gear is 8.8 or 9.75. I have seen posts that said if the diff cover has 10 nuts its 8.8 but if it has 12 its the 9.97. I know there's a tag on the diff with codes, I'm hoping there's an easier way to tell than having to climb under the truck.
Any and all help is appreciated.
Bluegrass 7 06-25-2014 04:12 PM
Get under and look.
Suppose your told wrong?
The truck had several options for size depending on model and build.
H9 is the ratio and open or limited slip ID.
Good luck.
bluecobra 06-25-2014 06:00 PM
Thanks Bluegrass,
I did get under and its a 9.75 RG.
steve(ill) 06-25-2014 08:55 PM
http://ts1.mm.bing.net/th?&id=HN.608...d=1.9&rs=0&p=0
this is the smaller 8.8 inch - note cover circle
steve(ill) 06-25-2014 08:56 PM
http://ts1.mm.bing.net/th?&id=HN.607...d=1.9&rs=0&p=0
9.75 is more egg shaped
STOFFERJ 06-29-2014 10:21 PM
all 5.4 equipped F-150's had 9.75's from the factory
bluecobra 07-01-2014 03:50 PM
Got bearings & seal for the 9.75. Pulled the old ones and discovered the the 9.75
bearings were too big. It took the 8.8 bearings instead. Go figure!
