<p>
Originally Posted by fordboy2
(Post 14498036)
Mine did not have the updated stc either. I dont know that it matters though at this point.
<p>A remanufactured OEM pump will come with the revised STC.</p> |
(Post 14497984)
I read through the thread but did not grasp what you were tryng to point out to me. Mine is the new style pump as mine is the 2005 model year. As mentioned is blowing air directly out of the pump back side. I assume this is a failed pump but I have no prior knowledge to say that it is.
Ok no big deal I just wanted to make sure you were not trying to tell me something I was not grasping. Well guess I am off to spend some money.
The thing I question is if this is also why I had a hot hard start
(Post 14499004)
The stc looked somewhat questionable. The ipr is new as I just bought it.
I had just put the new stc on when I discovered the air coming out of the rear of the pump.
How much cranking will it take before I start to c it build pressure?
Also just an fyi for people trouble shooting in the future there was air coming out of that same hole after the new pump install so I doubt I had a bad pump.
Well I have cranked the hell out of it with it never building over 21 ICP. I give up, anyone wanna buy a 6.0 that doesn't start?
(Post 14499525)
Originally Posted by mustang_309
(Post 14499553)
Are you showing oil pressure on the instrument cluster while cranking?
(Post 14499594)
Yep and when I checked the oil filter housing filled up at an acceptable rate.
(Post 14499635)
Ok that is good news, now did you get a scan gauge or something that will read more than the livewire does? It would be helpful to know what the ICPV's are KOEO. Have you tried starting it with the ICP sensor unplugged ( located in the passenger side valve cover ) ?
If your referring to the ICP reading KOEO it's at 0 right now.
